Parting out 1982 XJ650 & XJ750
Discussion in 'For Sale, Trade/Swap, Wanted' started by mcmechanic, Jul 17, 2012.
  1. mcmechanic
    mcmechanic New Member
    I have all kinds of parts for XJ650's & 750's
    Let me know what you are looking for....I just might have it!!!
  2. trickedout420
    trickedout420 Member
    Greenwood MO
    i need an auxiliary light switch..lemme know
  3. fuggers
    fuggers Member
    Have a seca? I need the right side muffler
  4. Buffalony
    Buffalony Member
    Corning NY
    XJ650J looking for clean headlight bracket, mirrors, luggage rack, and clean front blinkers? PM me if avail.
  5. FrankenSeca
    FrankenSeca Member
    Gillette, WY
    I need a gas tank. Prefer a 750 Maxim but could use a 650 Maxim. Please send me a PM.
  6. gangstahats
    gangstahats Member
    I'm interested in XJ750 SECA Front Rotors (11.73 dia & 5MM thick) / Mounting Bolts and Locking Tabs . .
    I can do $40.00 shipped ! ! ! USPS Priority Flat Rate is at $11.35
    I am looking for several sets of these ! ! ! !
    Let Me Know ! ! !
    --- THANKS ---
  7. LayItDown
    LayItDown Member
    Montgomery, AL
    Gas cap and key? And a exhaust manifold flange. For the 650
  8. Paiva
    Paiva Member
    Tewksbury, Ma
    I'm looking for forks for a Xj750 Maxim. Must be usable or rebuildable. Dual disk no anti dive
    Shipped to 01876. Thanks, Jeff
  9. Hollywood
    Hollywood New Member
    Salem, OH 44460
    hey, I can use the left side mounting bracket for the mirror and instrument cluster from th xj 650.....PM me if available
  10. matthewlee
    matthewlee New Member
    Hi
    Im am needing 4 usable and not cracked carburetor intake flanges for an 82 xj 650. Mine are cracked and leaking..
  11. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Am in desperate need of a started for the 650 if you have it.
    eman
  12. fuggers
    fuggers Member
    Why would you start a thread like this and then never respond to anyone !
  13. Paiva
    Paiva Member
    Tewksbury, Ma
    Ya, What he said!
  14. mcmechanic
    i send p.m's to whoever responds.....
  15. Teddycod
    Teddycod Member
    NE Tenn
    Handle bars and brake lever?
  16. Riley/MN
    Riley/MN New Member
    Wabasha County, MN
    Right side cover for the 750?
  17. jstnolson
    jstnolson New Member
    I need the LH controls that run the blinkers and headlight, and the rpm cable. This is for the 650.
  18. Jambo
    Jambo New Member
    what shape are the mufflers in? do want if still shiny.
  19. jeffcoslacker
    jeffcoslacker Member
    SW MO
    750 Max, looking for front turn signals, clutch lever if pivot hole isn't oblong, front brake light switch from master cyl, and a left side cover...or both if nice.
  20. wingwax
    wingwax New Member
    I've been looking for float bowls off of a XJ650 hitachi carburetor. If they're up for grabs, let me know, or if you need to sell the entire carb bank, I'd be willing to consider that.
    Do you have the stock 650 dual exhaust, too?
  21. TroyAG1
    TroyAG1 New Member
    Sandy, OR
    Looking for RH controls & Master cylinder for 650 - 97124
  22. motorheaddad
    motorheaddad Member
    San Diego Ca.
  23. Cmccully04
    Cmccully04 Member
    State College, PA
    I need xj750, 650 may be the same im not sure, Clutch handle, not the lever, but the part that actually mounts to the bars...I'll buy with or without the lever attached depends on the shape of lever itself.
  24. TroyAG1
    TroyAG1 New Member
    Sandy, OR
    PM'd who? cuz I didn't get one if you meant me.
  25. m-power1989
    m-power1989 Member
    hey got the REAR COWL AND TAIL LIGHT ASSEMBLY
  26. Kenny
    Kenny New Member
    Oswego NY
    I am looking for the complete exhaust (Minus the Mufflers), A speedo cable, tac cable, clutch cable, and right side mirror. Would you happen to have any of those and are you willing to ship them to Central New York? Please and thank you :)
  27. pmjydnl
    pmjydnl Member
    Sydney Australia
    I am looking for some lower fork legs. any luck there?
    I am also looking for the latch under the sear and the part of the latch that sits on the frame.
    cheers
  28. Trumpetrhapsody
    Trumpetrhapsody Member
    Fayetteville, AR
  29. VeggieLaine
    VeggieLaine Member
    Muncie, Indiana
    Do you have the right side control switch for XJ650 (the part that houses the starter pushbutton and ignition cut off).
    Thanks!
  30. VeggieLaine
    VeggieLaine Member
    Muncie, Indiana
    Thanks!
  31. Kwiski
    Kwiski Member
    High Desert CA.
    Got 750 Max Gas tank?
  32. snoproladd
    snoproladd New Member
    Looking for the Entire instrument cluster, preferably with the mounting brackets for the 750J...do you have them?
    BTW...Maxim 750J, not like it needs stating with the J but just in case.
  33. paulxj03
    paulxj03 New Member
    I'm looking for a set of carbs for the 750 maxim (83).
    Thanks.
  34. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    I could use the grips, if you can get them off in one piece.
  35. fishhookxj
    fishhookxj Member
    FLORIDA
    I WAS WONDERING ABOUT THE 750 ENGINE AND OR STARTER
  36. Yepesd
    Yepesd New Member
    Master cylinder, cable, and left and right hand controls for an 81 xj650 maxim
  37. MikesChevelle
    MikesChevelle Member
    I need a right side cover (battery cover) formy 83 maxim if you have one
  38. livingdeadlyxj650
    livingdeadlyxj650 Member
    kimberling city MO.
    Have non yic intakes for an 81 650 carb to head?
  39. letelenny
    letelenny New Member
    Hi, Do you have a 750 exhaust that would fit a 1983 maxim?
    Also looking for blinker parts.
  40. RickB
    RickB Member
    Southern Maryland
    Looking for fork parts. In particular, I need a serviceable upper bushing. This is the bushing that mounts in the lower fork, under the oil seal. I have an xj750rj, not sure what you've got. Please let me know. Thank you for your help.
  41. rd2xj
    rd2xj New Member
    melbourne, australia
    i need carburetor for xj650
  42. livingdeadlyxj650
    kimberling city MO.
    i also have been looking for a carb . need an hitachi for a 650 let me know what u have
  43. Zekiniza
    Zekiniza New Member
    I'm looking for side farrings for my 550 got any? And would they fit?
  44. pickardracing
    pickardracing Member
    Two Rivers, WI
    Need a non-rusty fork tube.
  45. hogfiddles
    Has ANYONE actually gotten a reply? On July 26 there was a post that said "i send p.m's to whoever responds....." yet I see repeated requests, or parts being asked about. It would be nice to know if something is/was actually sold.
    Dave F
  46. razz1969
    razz1969 Active Member
    Cleveland, Tx
    spare 750 engine?
  47. razz1969
    Cleveland, Tx
    spare 750 engine?
  48. tpad365
    tpad365 New Member
    could use a right side cover and a gas tank sending unit for a seca 750.let me know please
  49. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    looking for left and right plastic side covers for 82 seca 750 . do you have any ... color not important
  50. slomo85
    slomo85 Member
    Imperial Beach, CA
    xj750 frame with title??
