Custom 4 to 1 to 2 exhaust W/ video link
Discussion in 'XJ Modifications' started by Wrench26, Jul 16, 2012.
  1. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    Well since i had to fix the exhaust i desides to do it right and final time. a 4 to 1 collector to dual exit each side of tire. i should have it completed tonight when i get off work. if all goes well and then finish welding at work. the exhaust will get wrapped and the tips will be painted. don't know what color any anythign like that yet.
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Re: Custom exhaust exit under bike
    4 into 1 into 2? LOL :)
  3. earz_cd
    earz_cd Member
    Jefferson city, MO
    Did you get it finished? How does it look/sound/run?
  4. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    not yet should be finishing tonight.. i moved my kick stand forward almost to front of bike frame to make room. its going to be all one piece so may be fun getting on and off but not to worried about it. should sound sick installing a perferted piece of metal in collector to give a little back pressure. but estimating a very beasty sound
  5. earz_cd
    earz_cd Member
    Jefferson city, MO
    Doh!! I should have checked your post date. Sorry.
    Be sure to post some video or a sound clip or something. :)
  6. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    well the preliminary welds is done not my best work but is a smooth flow inside. will run a drill with honeing beads when done. now i have to finish all final welds and close up the collector. them also put a small baffle inside collector to give some back pressure. here are some pictures. i will be wrapping exhaust to hide my crappy weld job for sure...
  7. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    Re: Custom 4 to 1 to 2 exhaust
    well its done. but need to add baffling to give more back i have one baffle right now in the middle in the shape of a V. Very loud. going to add two side baffles to cause cross interference of the exhaust gasses just after exiting the down pipes.
  8. BennyBobber333
    BennyBobber333 Member
    Upstate NY
    looks sick. i hope you can post a video somewhere and let us hear it. I want one as well for my bobber. How much to fab and ship another? Would you consider it? Great job. Looks tough.
  9. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    Ya i could i just need to get the adapter to the exhaust ports. i need to make another one for my bike and get a baffle setup that will allow more persise tuning. But don't know cost took about 6 hours of straight work. I have to find a bushing for the rear so it can float with the engine. so still some work but would make it. will have to do some calculating on the cost. And designing of the collector need to be better. You also have to move the side stand forward and remove the mid stand.
  10. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    i believe i have come up with a fix for the low back pressure. i will add a reducer cap on the exit pipe that along with the baffle i added should give me the sound and back pressur needed. i attached the quick fix. if it work i will just weld on to pipe. if i need more i will add a screen that i can add packing to it. Can someone give me the diameter of the stock exhuast holes
  11. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    Here is the link to how is sounds need to do some more fine tuning of exit hose a little bigger but the prototype is complete...
    http://youtu.be/xXkzfQv-Cak
  12. trickedout420
    trickedout420 Member
    Greenwood MO
    that sounds awesome
  13. Sabre
    Sabre Member
    Lansing, MI
    That does sound pretty good. I'd be interested in what it sounds like in a high-RPM pass. Say, 7-8000 RPM in 3rd or 4th gear.
  14. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    will have my friend help me out with that but will get it for you all to hear.
