VERY simple and nooby question about oil
Discussion in 'XJ Technical Chat' started by timbojim, Jul 25, 2012.
  1. timbojim
    timbojim Member
    Kelowna, BC, Canada
    first: what kind of oil should i use, 15-40 or 20-50?
    second: where is the oil window and where should the oil go up to on it?
  2. bigfitz52
    20W50, and only motorcycle-specific oil such as Castrol 4T.
    The oil level window is on the clutch cover, below the "bulge" and the oil level should be above the upper marks but with a small bubble visible at the top.
    Oil must be checked with the bike on the CENTER stand (or held vertical) and after being OFF for at least 10 minutes.
    Your oil capacity is expressed as "CM3" and is cast onto the clutch cover adjacent to the filler hole. For instance, 2500CM3 means 2500CCs.
  3. timbojim
    timbojim Member
    Kelowna, BC, Canada
    Thank you.
  4. mtnbikecrazy55
    oops wrong thread, i use castrol 4t, motorcycle specific, pretty heap at 3-5 bucks a qt.
  5. mtnbikecrazy55
    p.s, stay away from synthetics, or they can cause clutch slipping problems!
  6. maz43
    maz43 Member
    Detroit area
    Synthetics got my starter clutch to slip....
    Maz
