chargng problem, not the usual supects SOLVED!!!
Discussion in 'XJ Technical Chat' started by danielcarver47, Aug 1, 2012.
  1. danielcarver47
    danielcarver47 Member
    carolina borders
    hello all regarding my 1981 xj750 i am only getting .50 volts at idle and 1.75 volts at around 6k rpms. i hve isolated wires from brushes and stator to thr rectifier so we can skip the loosewire/bad fuse idea.
    stator wires test at .08 ohms, brushes test at 4.3 -5.6 all within reason according to haynes book. i replaced the stator and rectifier off a running bike.
    his brings me to possible fried rotor but i am ite sure they rarely go bad and if so why is it testing good.
    bruhes are good, stator is clean, connections are good. im at a loss
    thks in advance for any help
  2. adrian1
    adrian1 Active Member
  3. wwj750
    wwj750 Member
    central minnesota
    Re: chargng problem, not the usual supects
    O.k.--I'll ask. How's the battery? Adrian1-great link, thanks.
  4. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    OK, check the 8 wire(?) connection behind the battery....I found that mine had actually melted when my charging system failed....
    Also, this is your one warning....DO NOT BUY A STATOR FROM ELECTROSPORT(or Ricks as he sell them)!!! If you want to meet a whole bunch of people who will tell you about their buying them and having them fail right out of the box, then having to go through hell to get it replaced, take a wander over to the Vstrom forum and search "Stator"....and you'll meet lots and lots of them! The ones that didn't fail out of the box had very crappy capability....like 12.8 at 5000 rpm
    This is a real case of cheap=junk.
    jeff
  5. danielcarver47
    carolina borders
    oh yea, forgot to mention, new battery, everything was totally rewired when i chopped it into a cafe racer, unfortunately someone i gave it to buggered it up but thats another story. i cant say when it started because when i bought the bike i only test drove it for a mile or so and it may never have worked. i have had the stator cover off a number of times, rotor is clean, copper disc where brushes meet is clean im really leaning toward the rotor but it wanted to see if anyone had a better idea before i spend more money. the tests i listed above are with the wires from stator and brushes going directly to rectifier and battery unhooked from the circut.
    pics of bikes here http://www.flickr.com/photos/11184427@N06/
  6. Polock
    How do you get .5 and 1.75 running when it takes about 10 to make the bike run. Your doing something wrong.
  7. danielcarver47
    carolina borders
    the .5 and the 1.75 are with the lead to the battery unhooked that is straight off the rectifier bypassing the battery
  8. danielcarver47
    carolina borders
    adrian 1 dude, thanks a million for the link, thats just the ticket. ill keep yall posted. the diagram is exactly what i needed to figure this calamaty out.
  9. Polock
    don't do dat, hook the battery back up and start over
  10. danielcarver47
    carolina borders
    shoot polock, how the f*** did i miss that, i read the haynes book a zillion times, now thats a rookie move im gonna keep kic king myself
  11. danielcarver47
    carolina borders
    adrian1 is the hero of this thread, cant thank you enough for the link to the troubleshooting chart.
    the culprit was the brown wire, i had checked continuity and resistance to the brushes but neglected where it feeds into the switched fuse block, i assumed (silly me) that the new wire i had run was good, after a continuity test, turns out it was faulty, guess you get what you pay for and i got the wire at harbor freight tools (cheap) i couldnt visibly see any breach to the coating of the wire but end to end it had a big fat goose egg on resistance, who woulda thought 8 cents worth of wire would cause such a hassle.
    also thanks polock for pointing out the obvious, sometimes we tend to over think things in the heat of battle and need a nudge back into the realm of common sense.
  12. JeffK
    "and need a nudge back"
    You're lucky, he usually nudges with a 4by4....lol
    jeff
