Front Suspension - fender fitting
Discussion in 'XJ Technical Chat' started by jmcgee14, Aug 2, 2012.
  1. jmcgee14
    jmcgee14 New Member
    Massachusetts
    I have a 1981 XJ550 which when I bought it had some stupid modified/cut fender on the front which I wanted to replace with an original or a full fender of some kind - I bought an original replacement but it did not fit - it bottomed out on the tire before the bolts lined up - So I am assuming the front forks were changed or moved or something
    Can anyone tell me how to measure or get an ID on the front fork set up so I can install a new fender?
  2. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    What size tire is mounted?
  3. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Crap - thats a good question - Im currently at work and wont be able to get the dimensions until later
  4. mtnbikecrazy55
    that might be your issue, because it would be unlikely that someone would chop the forks from the bottom. usually they would just slide them up in the triple tree more.
  5. mtnbikecrazy55
    what you should know however, is that the fender is a key piece in the alignment of the forks, and is also provides structural support/alignment.
  6. fintip
    fintip Member
    Austin
    ^That is very useful information, and might explain my fork issue: a guy hit the fender ripping the bolts in half that hold it on the left fork, and now the whole thing is askew, but it was a relatively slow collision (4-6mph?) and I can't see any visible damage on the forks, and nothing ever collided with the forks (I think).
  7. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Ok I have the tire sizes -
    front, 100/90-19
    rear, 130/90-16
    Sorry for the delay - and thanks for the suggestions!
  8. hogfiddles
    Two quick questions:
    1. Can you show us a picture of the forks and fender? If you have the wrong fender, we'll spot it.
    2. IF you do need new forks, I do have a nice set from a 550 maxim that I parted. I may have a fender, but not sure........
    PM me if you end up needing forks.
    Dave F
  9. fintip
    fintip Member
    Austin
    Those are the correct size tires.
  10. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Thanks fin!
    Dave F - I have a couple pics up already on my profile - I wont be able to upload any close ups until I get home from work
    I just looked into my purchase history from ebay (where I got the fender) and I realized that I ordered a front fender for an XJ 550 Seca - not a maxim
    Perhaps this could be the issue hmmmm...... :roll:
    In my defense it wasnt until I signed on here and met Len from XJ4ever that I learned I had a Maxim
    The guy who sold me the bike gave me the wrong owners manual which led me astray
    I'll still get the pics up later this evening to verify
    Thanks everyone!!
  11. mtnbikecrazy55
    Theres your issue :wink:
    I looked at the pics in your gallery - nice bike, but i'm glad you're going back to a real fender :lol:
    Get a maxim fender and you should be good to go
  12. mtnbikecrazy55
  13. mtnbikecrazy55
  14. bigfitz52
    I most likely is. The two bikes have different style front forks and the fenders are not interchangeable. I've got a 100/90-19 on the front of one of my 550 Secas and it fits fine; so it's not a "tire size" issue.
  15. SecaMaverick
    Northeast Ohio
    Errr... sort of, depending on whether you install the front wheel and axle/bolt before or after you put the fender on. If the wheel's off, then yes, the fender aligns/rotates the forks to each other. But if the wheel and axle is installed first (which I do frequently), both forks are already aligned to each other and can't be moved.
  16. mtnbikecrazy55
    I always install the fender first because its easier to line the bolts up with the damn brake line brackets, lol
  17. jmcgee14
    jmcgee14 New Member
    Massachusetts
    Thanks everyone!
  18. fintip
    fintip Member
    Austin
    The fender does seem to act as a hard brace holding it all together--the triple trees have 'give' under force, the fender has to break to allow misalignment (as mine did).
  19. bigfitz52
    That's because the stock Yamaha fender includes a very stout (stamped) fork brace "hidden" under the mounting areas.
