Rear Brake
Discussion in 'XJ Technical Chat' started by MisterShah, Aug 12, 2012.
  1. MisterShah
    MisterShah Member
    Tucson, AZ
    Hello everyone,
    I just changed both my tires on my XJ. After putting the tires back on, my rear brake is not working at all. I have adjusted the arm and the rod several different ways. No matter what I do, the brake pedal will go way down and the tire will not stop moving at all. I just ordered new shoes yesterday, but my brakes were at least stopping my tire before the tire change.
    Is it possible I did something wrong when re-installing the tire and brakes? Just seems odd that there is zero friction now.
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    yep your going to have to pull the tire back off and have a look.
  3. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I had something that looked like that. The splines on the cam were broken and the lever just spun. See if the cam is turning.
  4. patmac6075
    patmac6075 Active Member
    MKE
    It's pretty simple mechanism...most likely JP is correct, but you're still going to have to pull it apart.
  5. MisterShah
    MisterShah Member
    Tucson, AZ
    No, the splines are set and the rod rotates with the arm. Gonna have to pull it.
  6. JPaganel
    Minneapolis
    Then there is something wrong with the shoes. There isn't really a way to install the cam wrong and still be able to attach the lever to it.
  7. MisterShah
    MisterShah Member
    Tucson, AZ
    I figured as much. I have new shoes arriving sometime this week, but I still have to be able to ride til then. So, I shall do some investigating to see if I can get 'em working for the next few days.
  8. crowdpleazer
    crowdpleazer Member
    pull the lever on the drum by hand. its hard to pull but you should be able to get the brakes to drag a little. if not then your problem is in the drum...
