KROIL...... A CHEAPER AND MORE READILY AVAILABLE ALTERNATIVE
Discussion in 'XJ Technical Chat' started by Franga, Aug 17, 2012.
  1. Franga
    Franga New Member
    Ok guys.... Here is a cheaper and more efficient alternative to Kroil.
    50/50 mix of Automatic Transmission Fluid and Acetone. Mix in a jar and screw on lid. When needed shake jar and apply with brush, and treat job as you would with Kroil. The mixture will separate, as most mixtures do, if left sitting long enough. Shake jar before use. It really does work.
    APPRIECATION CAN BE EXPRESSED BY DONATIONS OF COPIOUS AMOUNTS OF BEER! :D :D :D
    BenBeenBanned@VWVortex said:
    Some of you might appreciate this. Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts.
    They are below, as forwarded by an ex-student and professional machinist, Bud Baker.
    They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
    Penetrating oil ..... Average load
    None ...................... 516 pounds
    WD-40 ................... 238 pounds
    PB Blaster ............... 214 pounds
    Liquid Wrench ......... 127 pounds
    Kano Kroil .............. 106 pounds
    ATF-Acetone mix.......53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
  2. wizard
    The only reliable test would be on the same nut, but that can't be done, so all results are subjective.
  3. Franga
    Franga New Member
    True true..... But worth a go.
  4. adrian1
    adrian1 Active Member
    Interesting I wonder how just acetone would go....suspect the ATF is the carrier so the acetone doesn't evaporate immediately...
  5. fintip
    fintip Member
    Austin
    Awesome. If I'm ever in ozzie-land, I'll take you to a bar.
  6. bigfitz52
    I've had Kroil work where Liquid Wrench didn't.
    And at $6 a can for Kroil here in the USA, I dunno about all that much cheaper, either.
  7. Polock
    i've tried ATF-Acetone mix and it works but the acetone part tears up most paint and some plastic
    Kroil doesn't seem to
  8. Franga
    Franga New Member
    Re: KROIL...... A CHEAPER AND MORE READILY AVAILABLE ALTERNA
    No dramas...... Most of my bikes are rats so no worries with the paint fryin up.
  9. mtnbikecrazy55
    especially for the 2for12 deal on the king aerokroil.
    but nifty idea if it works and you're out of kroil! 8)
  10. bkerby
    bkerby Member
    MO
    My brother in law uses this mix on the farm with great success. He has been an advocate for kroil for years but believes the home brew is quite a bit better.
  11. Groundswell17
    Groundswell17 Member
    Maryland, US
    i think this is great :) i'm def gonna give it a shot some time, yeah it will eat paint obviously, acetone. thanks!
