XS vs XJ what the difference???
Discussion in 'Hangout Lounge' started by le_bucheron, Aug 15, 2012.
  1. le_bucheron
    le_bucheron New Member
    I just purchase my first motorcycle. This is a xs1100 1983 (canadian). I would like to find a post that explains the differences between xs and xj. Especially if they share the same parts???
    thanks
  2. TIMEtoRIDE
    Welcome to the site !!
    It's all about styling and cosmetics.
    Spiral rims, more teardrop tank shape than the SPECIAL XS1100
    Don't expect Maxim 1100 trim parts to work on your bike.
    I think they also dropped the vacuum advance, so only get ignition parts for your bike, otherwise the motors are basically the same.
  3. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Welcome to the forum mate.
    So that will be an XJ1100 from 1983 and not an XS1100.
    The engines are mainly the same, except the XJ has got the YICS cylinder head, the middle gearbox and final drive are the same. The wheels are the same as the XS1100 Sport, the forks are different as they have air assist linked by an air line between the forks, i think the XS Sport had a valve on top of each fork leg. Brake calipers are the same as XS Sport, but the XJ has got a linked system. Ignition systems are different between the XS and XJ. Carbs are different.
    You'll find a lot more info at www.xs11.com.
  4. hogfiddles
    and the xj1100 has the octopus fuel line stuff.....don't know about the xs.
    dave f
  5. mlew
    There is basicly no difference in the engine/chassi, its the tank and trim that is very different. The wheels will interchange between the XS/JX1100, I have XJ wheels on my XS11, I like the swirll pattern.
    Most every engine or carb part will interchange but there are some small differences in jetting and engine controls.
    Want to know more? Go to xs11.com.
  6. le_bucheron
    Here my bike!!! So is it a xj or xs???
    Thanks for help!
  7. kjohnson
    kjohnson Member
    Wetaskiwin, AB, Canada
    That is most definitely an xj1100.
  8. MiGhost
    MiGhost Well-Known Member
    11G in the VIN is the designator for the XJ1100.
    The YICS, octopus, wheels, gauges confirm that.
    Looks like a good starting point.
    Ghost
  9. le_bucheron
    Thanks!!! I only paid $ 300 for the bike. It will be my project for this winter.
  10. le_bucheron
    Another question. Is that I have a good model of the rear shock or it would be preferable to an upgrade??? I want to make a bobber
  11. mlew
    You could upgrage to new modern shocks but the XJ11 shocks are prety good and they are rebuildable and tuneable. I use them on my XS11, V-Max and XJ11. Keep them, if you decide not to use them I need the rubber shock boots.
  12. mtnbikecrazy55
    mlew! you dont have an xj anymore? :(
  13. mtnbikecrazy55
    oops. i see 82 xj1100
    im blind
