Signal Lights
Discussion in 'XJ Technical Chat' started by viper, Aug 2, 2012.
  1. viper
    viper New Member
    Just bought a 1981 650 maxim and am having issues with the signal lights.. both sides come on but do not flash, thinking flasher relay.. Can someone confirm this for me.. thanks
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    The original lamps were 27 watts, if you changed the bulbs to anything other than these , they will not flash. You can however use an electronic flasher but to will loose the auto canel function.
    MN
  3. maverickbr77
    maverickbr77 Member
    Lowville, New York
    first off are the original flashers on it. The stock flasher needs the full draw of the stock bulbs to flash. After that I would guess flasher.
  4. readlee
    readlee New Member
    Twickenham
    I had this problem, the 2 pin flasher is dodgy! I managed to fit a CF13 3 pin to my xj750. Brown is + and connects to B+ pin, the Brown/White is your BULB side which connects to L pin. Lastly, you need to connect E- to the frame or and earth wire. You can leave the Yellow/Green wire, which is your auto off trigger.
  5. AlexDonaghue
    AlexDonaghue Member
    not sure this is my problem but my right flasher works, horn, headlight, highbeam, break light (front and rear) everything BUT my left flashers?!?! how would i narrow down the problem for this? the fuses are good and the bulbs work.
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Alex: your symptoms would mean the problem is from the left side of the switch on to the bulbs. first guess it that the contact is corroded if not maybe a bad socket, but if you tested the bulbs you should have seen a corroded socket. past that follow the wires.
