Custom Velocity Set up for under 135
Discussion in 'XJ Modifications' started by Wrench26, Aug 23, 2012.
  1. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    Hey guy been working on a carb fix when running pods. I have come up with the following. i should start making the jig this week.
    What is your guy opinion. I know velocity has worked from whay i have read helps control the air in elimiates the turbulance. help me out guy.
    Guy with velocity stack how was ur to tune and give some input
  2. hotsummer
    hotsummer Member
    Good luck!
  3. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    How do you plan to get a 100% airtight seal between the aluminum and carb body?
  4. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    i will apply a small amount of rubber coating used for coating tool handles and the machine surface will be with in 100th of an inch. hopefully.
  5. mook1al
    mook1al Member
    Talladega, AL
    Have you tried the factory airbox boots fitted to the pod boots yet?
  6. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    I just installed them tonight and will see how it act later this week someone stole my plate so I had to order another. So pissed but made a custom plate that will read cafe82 hell ya.... But will hope for the best
  7. TIMEtoRIDE
    Don't use Apoxy - - use Epoxy; it's good stuff :roll: :p
    Good luck with your invention.
  8. mlew
    How is the mold for the press going to be made?
  9. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Sand cast or positive/negative molding?
  10. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
  11. adrian1
    adrian1 Active Member
    That gauze will stop large pebbles but I'm not sure about the fine abrasives it will suck in.....:)
