Replica side cover emblem
Discussion in 'Hangout Lounge' started by hrc1966, Aug 28, 2012.
  1. hrc1966
    hrc1966 Member
    Southampton UK
    Just adding a picture if i can of a replica i have made of the XJ550 Seca emblem, left is the replica , right the original. Top s a CB900 Custom replica too. Bit blurry though sorry..
  2. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    That's pretty spiffy. How did you do it?
  3. hrc1966
    hrc1966 Member
    Southampton UK
    silicone , resin and patience..
  4. maverickbr77
    maverickbr77 Member
    Lowville, New York
    I am surprised more people aren't doing this its really not that hard to make a negative mold to make new emblems with especially as they aren't overly complicated on the xjs.
  5. yamamann
    yamamann Member
    Barrie, Ontario, C A N A D A
    I repaired my seca gas tank emblems ( they were missing the upper and lower parts of the YAMAHA letters ) using 5 minute epoxy and round handle needle files - it was a fun inside workbench project last winter. The finished product actually strengthens the entire emblem helping to prevent it happening again while buffing the tank after waxing. If anyone would like more detail on how to do it just let me know.
  6. karl
    karl New Member
    KS
    They look great.
    What product would I use to replace the gold coating on the gas tank emblems that has completely worn off?
    Info appreciated.
  7. hogfiddles
    gold leaf
    Dave Fox
  8. bigfitz52
    New badges?
    Truly the cheapest solution in the long run; especially tank badges.
    "Seca550" badges are a tad more difficult to find without paying $45 a pop. (But not impossible.)
    That being said, those are some nice looking replicas. Easily done with an original badge, by a hobbyist familiar with resin casting-- I suspect a fellow modeler.
  9. hrc1966
    hrc1966 Member
    Southampton UK
    Not a modeler, although i have a mate that keeps bringing me his parts for rebuilding when he crashes his planes. Its his flying skills that don't seem to work rather than my rebuilding that fails....and often down to electronics failing mid flight.
    The Gold is a foil, gold leaf is too flakey... excuse the pun..I can produce a pair a day with not a lot of effort.
  10. hrc1966
    hrc1966 Member
    Southampton UK
    Just added onto ebay ...
  11. mtnbikecrazy55
    further explanation? is this what you use OP?
  12. hrc1966
    hrc1966 Member
    Southampton UK
    The Gold is a foil, gold leaf is too flakey... excuse the pun. I thought i had, it was in a earlier message in the thread.
  13. mtnbikecrazy55
    What kind of foil? How do you apply it? How durable is it?
  14. hrc1966
    hrc1966 Member
    Southampton UK
    Gold Foil, glue, heat and a clear coat. I would say it is durable..
  15. mtnbikecrazy55
    so put the glue on the badge, lay a piece of gold foil, and then somehow cut the excess?
    then just clear over the whole badge? just spray krylon/etc?
  16. hrc1966
    hrc1966 Member
    Southampton UK
    Have no idea what krylon is..
