My Maxim Sticks at 3000 rpm
Discussion in 'XJ Technical Chat' started by Rvulcan500, Sep 3, 2012.
  1. Rvulcan500
    Rvulcan500 New Member
    Vermont
    Help, When I run my 1985 Maxim at 1000-2000 rpm it performs great.
    As soon As I hit 3000 rpms it gets stuck there.
    I have had a NEW throttle cable installed. I have had the carbs clean. fresh gas. new spark plugs.
    Can anyone help?
    thanks
    Ric
  2. bigfitz52
    Check and adjust (wet-verify and wet-set) your float levels.
    Then do a running vacuum sync. There's more to carbs than cleaning.
    How many miles on the bike? The "X" still needs its valve clearances attended to regularly; albeit on a much longer schedule.
    If whoever "cleaned" your carbs didn't actually know what he was doing, it's more likely a case of needing simple, proper adjustment.
    "Hanging" idle is generally a symptom of an out of sync condition or wonky float levels, or both.
    How's it run at say, 9000 rpm? (Not on the stand, of course, under load.)
  3. Rvulcan500
    Vermont
    I currently cannot run the bike. It is at my mechanics, Turner Built. The Bike stuck at 3000 rpm even when I revved it under load. ( I'm a fat one. 300lb.)
    No matter what I did it stayed at 3000rpm. When the bike sat for a bit it did run normal until I hit 3000 rpm.
    I hope this helps
    Ric
