how do I install...
Discussion in 'XJ Modifications' started by manimal, Aug 20, 2012.
  1. manimal
    manimal New Member
    Toronto ON. Canada
    I was wondering if some one can let me know how I would go about installing drag bars with a 6" riser on my XJ750 Maxim? I know how to install drag bars and other handle bars that don't have risers but I am clueless on how you would install handle bars that have risers on them.
    Also any suggestions on a good exhaust pipe to install that is loud enough to hear while cruising on the highway yet still has a deep rumble to it?
    If anyone can help me out here send me an email, panzertom@live.com
    Cheers
    Manimal
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    which maxim are you starting with 2 piece or one piece handle bars? the 2 piece may make it so you have to add a mount off of something like the 750 seca for the bars to mount to. What bars are you working with? some mount through the triple tree and others mount to the existing mount points.
    as far as exhaust I can't help you as I am all for quiet exhaust. I don't necessarily want to hear it and the only other people that will hear it (unless you go to completely obnoxious levels) are people on the side of the road or when your sitting somewhere, and I don't care if they hear it or not either.
  3. jeffcoslacker
    jeffcoslacker Member
    SW MO
    I had a Kerker 4-1 system on an old GS750 that just sounded wonderful...would sound great on the XJ750 too I'm sure.
    With the baffle out it sounded like a drag bike. With it in, it changed the sound to a lower note and had a nice beefy tone to t.
    It came with it, I think it was a pretty high-buck system though.
  4. adrian1
    adrian1 Active Member
    Think staintune make one suitable. They have a removable baffle too.
  5. Polock
    if you have the 2 piece bars, take the spline shafts off of the triple and use the holes to mount your risers.
    it's hard to get a deep sound out of a high reving 4
  6. hotsummer
    hotsummer Member
    You can directly discussed here can also help more people.
  7. davidpowell5
    davidpowell5 New Member
    how big are the holes to mount the risers? can you recommend any that fit?
  8. Polock
    Dave, don't do this to me. Normally I'd tell you to take yours off and look, but since your new I'll refrain.
    Your going to find a 8 mm hole for a thru bolt and a threaded 6mm hole.
    I used seca risers with 3/4 inch spacers, I know people have used tall risers but not what kind
  9. davidpowell5
    thanks I appreciate it!
  10. permissiontolandfmx
    permissiontolandfmx Member
    Edmonton, Alberta Canada
    swap your top clamp out from the spline version. MAC exhaust 4-2
    I love mine.
