Gel Battery?
Discussion in 'XJ Modifications' started by Roverking, Sep 19, 2012.
  1. Roverking
    Roverking New Member
    Building up my 81 Seca 750 and would like to locate the battery under the seat, however I would have to lay it on it's side. Not likely with a normal battery. I've read one post that said do not use gel batteries. Anyone used one? Any other suggestions?
  2. Rhettb3
    Rhettb3 Member
    South of the cities, MN
    I would go AGM if you can... can't remember why your not supposed to use gel.
    When I got my bike it had a 5 year old AGM in it. Started in the dead of winter with zero effort.
  3. Roverking
    Can you run an AGM battery on its side?
  4. osprey1000
    osprey1000 Member
    Annapolis, MD
    Yes, AGM batteries can be oriented in any configuration. Another reason why they are great batteries for bikes, beyond their vibration resistance and other great properties.
  5. Polock
  6. adrian1
    adrian1 Active Member
    Get a motobatt battery
  7. Roverking
    Motobatt Battery seems like a good one. A little expensive though.
  8. darkfibre
    darkfibre Member
    Perth, Australia
    I run a Motobatt, haven't needed to use my c-tek charger in the 2.5 years I have had it.
