Petcock rebuild
Discussion in 'XJ Technical Chat' started by dmlyster, Sep 19, 2012.
  1. dmlyster
    dmlyster Member
    Corvallis, Oregon
    '83 XJ750 Maxim obvioulsy has bad petcock. Fuel flows 'RES', 'ON', and 'PRI' position. Filters missing so use inline filter. I use shutoff valve downstream of inline filter. I would love to buy a new one but really need to do a rebuild ...... How difficult is this and what are problems to look out for in the process?
  2. bigfitz52
  3. dmlyster
    dmlyster Member
    Corvallis, Oregon
    thanks a bunch. somehow missed it in postings. looks like a winter project.
  4. mlew
    Don't wait that long to fix it. It will only take an hour or two for the job.
  5. Ted
    Ted Member
    Sioux Falls, SD
    I did mine about a month ago with one of Chacal's rebuild kits. Very simple and effective. Like Mlew said, it only took an hour or two tops.
  6. permissiontolandfmx
    permissiontolandfmx Member
    Edmonton, Alberta Canada
    I went and picked up a used on/off petcock and got rid of the vacuum.....straight gravity feed and no issues, and it was only $10.00
