Gas tank dent
Discussion in 'XJ Technical Chat' started by nickbrit16, Sep 23, 2012.
  1. nickbrit16
    nickbrit16 Member
    Ohio
    Anyone know a good and maybe cheap way to pull a dent from a motorcycle tank? Left side right below the emblem, not creased.
  2. jeffcoslacker
    jeffcoslacker Member
    SW MO
    I've heard and seen many ways...never tried any though so I can't say with certainty...
    I saw a video clip where they heated the area real hot with a hair dryer, then sprayed it immediately with one of those "canned air" keyboard dusters, held upside-down to get the cold liquid shot...metal rapid contracted, dent popped itself. PING! Way cool...
    I've been wanting to see if it really works. I got a plethora of dents on this one, I'll get around to it...
  3. nickbrit16
    nickbrit16 Member
    Ohio
    Yeah i seent that video too, i heard that dry ice sealed off inside the tank will pop it too, just dont know which one to try!
  4. mook1al
    mook1al Member
    Talladega, AL
    I wouldn't do the dry ice thing, that stuff is basically a bomb and might do more damage than good. The heat and then freezing thing might work, but a hair dryer will not get it nearly hot enough. Personally, if the dent is shallow and not creased, I would just use body filler on it. I had 3 small dings on my tank, none of them creased, and the tank looks fantastic.
  5. jeffcoslacker
    SW MO
    Ooo, yeah you don't wanna try sealing dry ice in anything. That could go wrong quick.
  6. BluesBass
    BluesBass Member
    Clementon, New Jersey
    I've patched dents in two Maxim tanks, a 650 and a 750. In my experience none of the 'easy' dent popping methods work too well. Your choices are weld a stud to pull the dent or just fill it with body filler. I have filled a dent successfully and combination pulled/filled a dent. You do have to repaint but it will get the job done.
  7. junkmn
    junkmn Member
    Colorado
  8. mtnbikecrazy55
    try a plunger, ive used it on cars with success. a tank might be harder but its worth a shot i figure! beats having to weld a stud and then re-painting
  9. fintip
    fintip Member
    Austin
    mrmaxstorey on youtube has a great video on practical cheap fixes for pulling dents out of motorcycle tanks. Look it up.
