1985 xj maxim 700 wiring/starting problem any help please
Discussion in 'XJ Technical Chat' started by izhakiori, Oct 16, 2012.
  1. izhakiori
    izhakiori Member
    hey i am 18 years old and wanted to start working on motorcycles but am really in need of help. i bought a 1985 xj700 a couple months back and it was in terrible condition the lady i bought it from claimed her son dropped it by the house in 2007 and it has been sitting since.
    i cleaned the carbs a little, switched spark plugs, replaced the gas tank with a 1979 Suzuki gs1000l tank, oil and filter change, new battery. i tried staring it but would only give me a roar and then die. it once started and continued while i was holding the gas but the second i let go died again. ( it was spitting a lot of oil from the crankshaft valve when i would try starting it at first but doesn't do it anymore)
    it wont start and i see i have 2 sets of wire not attached to anything i have a set that is a black, and blue/yellow wire. then i have red/yellow, blue/yellow, black/yellow, and black. ( the wire for the gas tank are also not attached because i have a different tank now and it has different wires i hope it doesn't change anything). i got hold of a service manual online but the wiring diagram is the most confusing thing i have seen in my life.
    im not sure if those wires play a role in the bike not starting but i really need help i am all alone i would appreciate any help!!!! thank you
  2. wwj750
    wwj750 Member
    central minnesota
    Welcome to the forum, you've come to the right place. If you got it to fire up, the primary problem is most likely gummed-up carbs, not electrical. The carbs will need to be completely cleaned, adjusted & synched, AFTER the valves are properly adjusted.
    You've got some work to do. You'll need a manual. Read some threads here on carb cleaning, the Church of Clean is really good.
    Hopefully one of the more experienced members here will chime in with a more complete "must do" list. Stick around, learn about your bike & how to work on it & you'll be rewarded with a good, dependable motorcycle. Good luck to ya.
