will Seca turbo charger fit 750 Maxim?
Discussion in 'XJ Technical Chat' started by SnoSheriff, Aug 26, 2005.
  1. SnoSheriff
    SnoSheriff Site Owner Staff Member Administrator
    MB, CAN
    Will the 650 Seca turbo boost fit on my 750 Maxim? If not, what type of mods would I need to make to make this work? Would this have any side effects on the bike lifespan? Sure would be nice to have Maxim turbo
  2. spinalator
    spinalator Member
    Regina, CANADA
    You can turbo anything you want but I really dont know about compatibility of the 650 vs the 750. One guy on STN has turboed about 5 bikes for drag racing and clutches seem to be the main problem for him.
  3. capy
    capy Member
    Florida
    your biggest problem would probably be from pre ignition. If I remember right, your bike has a 9.5:1 compression ratio. You may find that you may need to lower this to accomodate the turbo to prevent preignition and destroying the motor.
  4. pistolpete
    pistolpete New Member
    FOCO
    It would be much easier just sticking the 650 turbo engine with a big bore kit on the 750 IMO. You get the larger displacement turbo without the headaches.
  5. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Easier still would be to swap in a 900 Seca engine, with no turbo issues, and the big bore kit factory installed.
