Wanted:float pin for 1985 xj700 maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by Hosethe3rd, Dec 7, 2012.
  1. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    I have one but it is bent please help
  2. hogfiddles
    Did you try straightening it?
    Otherwise, get it from Len at xj4ever
    dave
  3. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Yes I went there and could not find it
  4. RickCoMatic
    Use a section of the Shank from a large Pop Rivet.
    Some Ball-point Pens have solid Ink-tubes that substitute nicely.
  5. TIMEtoRIDE
    Don't forget to polish the substitute, the other pins, and the internal surface of the float hinge with 1,200 - 1,500 grit for smooth operation.
    Everyone reading this should have done this "chore" by now.
  6. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
    Would one From a. 1982 xj550 work
  7. hogfiddles
    Hose..........from the xj4ever catalog:
    fs7) OEM Hitachi fuel bowl FLOAT HINGE PIN, brand new steel pin used with the HCP2 floats above. Fits all XJ650 (except Turbo) models, all XJ700 non-X models, and all XJ750 models.
    HCP3 Hitachi carb FLOAT HINGE PIN, each:
    $ 8.50
    HCP3SET4 Hitachi carb FLOAT HINGE PINS, set of 4:
    $ 29.00
    HCP5190 OEM Mikuni FLOAT PIN, fits all XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and all XJ1100 models, each:
    $ 2.95
    HCP5190SET4 OEM Mikuni FLOAT PINS, set of 4:
    $ 10.95
    Dave F
  8. Hosethe3rd
    Hosethe3rd Member
    Ladson sc
