Maxim valves are super TIGHT...
Discussion in 'XJ Technical Chat' started by RickB, Dec 21, 2012.
  1. RickB
    RickB Member
    Southern Maryland
    Just checked the Maxim's valve clearances... man are they tight:
    Intake (in MILLIMETERS!!): 0.06, 0.06, 0.06, 0.03
    Exhaust (in MILLIMETERS!!): 0.11, 0.06, 0.17, 0.06
    On the bright side, at least I have one valve in spec, and based on the installed shims, I can reuse ONE of the other 7 shims...
  2. hogfiddles
    Got your pm, Rick.......will check after supper tonight. Pm'd back to you, too.
    Dave F
  3. RickB
    RickB Member
    Southern Maryland
    Got it; thanks Dave. Definitely no hurry; lots of other work to be done.
  4. bigfitz52
    Not surprising if they were ignored. When I got my '83 550, it had 7100 miles on it, completely untouched, and seven of eight were tight.
    This is why it has to be Job 1 when bringing an XJ back to life. (Which you already know; I'm pointing it out for the benefit of all the procrastinators reading this thread.)
  5. RickB
    RickB Member
    Southern Maryland
    Dave, finally ready to do those valves; PM sent. Thank you again for your help.
