engine swap question
Discussion in 'XJ Technical Chat' started by leelee86, Dec 27, 2012.
  1. leelee86
    leelee86 New Member
    Rancho cordova, ca
    I have an 82 xj750 seca and would like to find a new engine for it. Is there any other models that will work with little to no modifications?
  2. hogfiddles
    Any 82/83 xj750 engine will work w/o having to retrofit stuff. If I remember correctly.
  3. bigfitz52
    Any 1981~1983 XJ750 SECA engine will bolt right in; Maxim motors would be only '82~'83 and you would have to swap some shifter parts around.
  4. hogfiddles
    Oh yeah..........fergot about the shifter issue.
    That's Ok.....I know Fitz would straighten me out--
    Dave F
  5. leelee86
    leelee86 New Member
    Rancho cordova, ca
    Thanks for the replies. What about any smaller engines like a 650?
  6. hogfiddles
    best thing to do is to bring up a forum by Chacal, our resident guru. He has a write-up that he did regarding engine swaps, what you have to change, what you can keep, etc.......
    Get that and read it. It will give you every answer you need. I'd copy it for you but I lost the link on my last computer when it died.
    Dave F
  7. maverickbr77
    maverickbr77 Member
    Lowville, New York
    from the information overload hour http://xjbikes.com/Forums/viewtopic/t=27544.html
    XJ650 models:
    Since one of the most popular engine swaps is putting an XJ750 engine into an XJ650 frame, we offer the following tips and guidelines regarding what issues you might expect to have to deal with in regards to this popular conversion. Also note that XJ750 Maxim/Midnight Maxim engines mount differently than XJ750 Seca engines, due to the lack of the rubber engine mounting insulators on XJ750 Seca crankcases.
    * when putting an XJ700 (air-cooled) engine into a XJ650 Maxim, Midnight Maxim, or RJ Seca frame, please observe the following changes:
    - observe the same procedures and cautions as applies to using the XJ750 Maxim/Midnight Maxim engines. The air-cooled XJ700 engines use rubber insulators to mount them to the frame, but you will need to retain the XJ650 engine mounting hardware (XJ700 engine mounts are in a different relative position in the frame).
    - it is unknown which airbox boots you will need to use.
    - the XJ650 Maxim/Midnight Maxim use the same style shifter assembly as an XJ700 engine, but differ from the XJ650RJ Seca shifter assembly.
    - have to convert tachometer to an electrically driven version on all 1980-81 XJ650 Maxim, Midnight Maxim, and 1982 XJ650RJ Seca models.
    - the XJ700 oil level sender can be used.
    - will need to use XJ700 carbs and intake manifolds.
    - need to retain XJ650 exhaust system.
    - need to retain XJ650 wiring harness, except for the pick-up coils sub-harness. The pick-up coils on the XJ700 engines are different. Need to use the XJ700 TCI box.
    - when using an XJ700 engine, be aware that there is a slight gearing difference----the XJ700 models have a slightly different gear ratio, also, even though they share the same size rear wheel as the Maxim. Thus there will be a difference in the acceleration of the bike, depending on which donor engine is used.
    * it would be advisable to use the XJ700 swingarm assembly and driveshaft.
    * one note of interest: the XJ700 engines, although of the same basic design as the XJ650 and XJ750 engines, are actually a much more "heavy-duty" unit, employing some of the XJ650 Turbo and XJ900 internal engine refinements and upgrades, as well as using a stronger, 6-spring clutch system, and also a much larger and stronger u-joint and driveshaft.
    * when putting an XJ750 engine into a 1980-81 XJ650 Maxim or Midnight Maxim frame, please observe the following changes:
    - have to convert tachometer to an electrically driven version.
    - the original XJ650 oil level sender needs to be retained (unless the engine is from a 1983 750 Maxim or Midnight Maxim).
    - the 650 shifter side cover and all internal components needs to be retained, unless you want to keep the 750 Seca style shifter. The 750 Maxim style shifter may not work.
    - the engine mounting hardware for the XJ750 engine will need to be used (no rubbers on XJ750 Seca; XJ750 Maxim used the same basic hardware. Use the XJ650 front upper frame brackets when using a Maxim engine; the XJ750 Seca frame brackets when using a Seca engine).
    - will need to use XJ650 airbox boots.
    - will need to use XJ750 carbs (or re-establish the XJ650 carbs to XJ750 specs).
    - need to retain XJ650 wiring harness, except for the pick-up coils sub-harness. The pick-up coils on the XJ750 engines are different. Need to use the XJ750 TCI box.
    - when using an XJ750 engine, be aware that there is a slight gearing difference----the XJ750 Seca used a 18" rear wheel, while the XJ650 Maxim models used only a 16" rear wheel, and thus middle drive gear ratios are slightly different inside the tranny. The XJ750 Maxim models have a slightly different gear ratio, also, even though they share the same size rear wheel as the Maxim. Thus there will be a difference in the acceleration of the bike, depending on which donor engine is used.
    * when putting an XJ750 engine into a 1982-83 650 Maxim frame, please observe the following changes:
    - need to retain XJ650 wiring harness.
    * when putting an XJ750 engine into a 1982 650RJ Seca frame, please observe the following changes:
    - the original XJ650RJ oil level sender needs to be retained (unless the engine is from a 1983 750 Maxim or Midnight Maxim)
    - the 650RJ shifter side cover and all internal components are the same as those in a XJ750 Seca engine. The 750 Maxim style shifter may not work.
    - all engine mounting hardware for the XJ750 Maxim engine will need to be used (no rubbers on Seca engines; an XJ750 Seca engine uses the same mounting hardware as the XJ650RJ Seca, except for the front upper frame brackets, the XJ650RJ Seca frame brackets should be used. If using an XJ750 Maxim engine, you'll need to be creative.............
    - will need to use the XJ650 airbox boots.
    - need to retain the XJ650RJ exhaust system
    - need to retain the XJ650RJ wiring harness, except for the pick-up coils sub-harness. The pick-up coils on the XJ750 engines are different. Need to use the 750 TCI box.
    - when using an XJ750 engine, be aware that there is a slight gearing difference----while both the XJ650RJ Seca and the XJ750 Seca models used a 18" rear wheel, the XJ750 Maxim models used only a 16" rear wheel, and thus the middle drive gear ratios are slightly different inside the tranny on some engines. Thus there will be a difference in the acceleration of the bike, depending on which donor engine is used.
    * when putting an XJ900 engine into a XJ650 Maxim, Midnight Maxim, or RJ Seca frame, please observe the following changes:
    - although there are anecdotal stories of this swap being accomplished, we've never seen or verified the completion of such a project. There may be some engineering challenges involved due to the greater height of the XJ900 engines, as well as other issues.
    Besides that, the same guidelines as generally outlined in the XJ700 engine swap should be observed.
    * when putting an XJ1100 engine into a XJ650 Maxim, Midnight Maxim, or RJ Seca frame, please observe the following changes:
    - put down the tools and the torch and back s-l-o-w-l-y away from the bike.
    - 1100 engines are vastly different than the other XJ650/700/750/900 engines in design, style, size, etc., and attempting to put one of these engines into the smaller frames is likely to be a complete custom job. No other information is available. It would be wise to consider buying an XJ1100 model bike, and riding that, rather than trying to transplant just the engine.....
    1981-83 XJ750 air-cooled models:
    Most of the same consideration would apply as outlined in the XJ650 Section, just reversed. With the exception of the engine-mounting issues (rubber mounts on Maxim models, solid mounts on Seca models), all XJ750 air-cooled engines are basically identical to each other.
  8. hogfiddles
    Thanks, Mav,
    That's the file:)
    dave f
