650/750 engine gasket differences
Discussion in 'XJ Technical Chat' started by redlightningsvx, Jan 18, 2013.
  1. redlightningsvx
    redlightningsvx New Member
    Was looking on ebay for a engine gasket set and seen one for a 650 for $110 and a 750 for about $65. Are they both interchangable to one another or no?
  2. bigfitz52
    Depends on whether it's a YICS 650 or an earlier 650. The one for a YICS 650 would be quite similar to a 750, but probably not completely interchangeable. One for an early, pre-YICS 650 would NOT be at all.
  3. redlightningsvx
    Its a 82' YICS motor
  4. bigfitz52
    My point was that there are two "flavors" of 650, YICS and non-YICS.
    There was only one style 750 mill and it was a YICS motor.
    YICS 650 and 750 will be nearly the same, the pre-YICS 650 not.
  5. MiGhost
    MiGhost Well-Known Member
    As far as the 650/750 YICS engines go. The only difference in the gaskets is the cylinder base o-ring. This will be due to the larger diameter cylinder sleeves in the 750.
    650: O-Ring 93210-69434-00
    750: O-Ring 93210-71462-00
    All other gaskets/seals should be the same. Both the 650, and 750 YICS share a common case, and head casting.
    Ghost
  6. redlightningsvx
    Awsome thanks guys for the info
