1989 pre-diversion handle bars mod question
Discussion in 'XJ Modifications' started by george4765, Jan 20, 2013.
  1. george4765
    george4765 New Member
    Has anybody tried to mod or know how to mod the handle bars on this bike? I would like to raise the handle bars but have no idea if this can be done! Any help appreciated.
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i assume its a european xj600?
    if so its not easy as the bottom of the fixed 2 piece handlebars have a course serrated fixing.
    the only way i can see, is to fit some universal handlebar raisers like this
    http://www.busters-accessories.co.uk/pr ... bar-Risers
    then fit some one piece handlebars to the raisers.
    you would need some deep "u" shaped bars to raise them more than the originals
    you would also need to check the extra length needed on the cables , wiring and brake hose.
    stu
  3. george4765
    My bars are clip ons and. Need to get them high up but cannot find anything that will marry up to them . Been searching the web nowt there. Thank for help cheers mate. George
  4. bensalf
    yorkshire ,england
    clip ons ?? on a 89??
    so are they aftermarket ones, does the top yolk have mounting points on it .
    some pic's would help
    stu
  5. george4765
    Its a European bike and the handlebars are fixed each side (2 piece assembly) into a serrated type bracket that locks each handlebar into position. Just checking if any one else out there had managed to find an alternative handlebar solution. Will post pics tomorrow. George
  6. bensalf
    yorkshire ,england
    they're not clip ons as such, they are the standard fitting
    if they're like this, then answer is as i said above
    stu
  7. TIMEtoRIDE
    I'm thinking a couple longer bolts and a couple "pucks" cut from 1" marine grade plywood, or Polyurethane shock bushings.
    ( I want a 10,500 redline ! )
  8. bensalf
    yorkshire ,england
    yep, suppose that could be a solution, but the serrations would have to bite into the spacer material quite a lot , other wise the bars would tend to spin on heavy braking ,or when maouvering bike.
    i still think it could be a fix ,by fitting raisers and one piece bars.
    stu
  9. XJE
    XJE New Member
    Ontario
    sorry to wake an old thread, but ever find a solution to a 1 piece bar setup? I have a 2 piece setup just like this one.
    appreciate any help,
    thank you
  10. bensalf
    yorkshire ,england
  11. hogfiddles
