Amazing! Just When You Think You've Seen It All!!!
Discussion in 'Hangout Lounge' started by RickCoMatic, Feb 9, 2013.
  1. RickCoMatic
    If you like Engineering.
    If you enjoy things built with Precision.
    If you marvel at what a Machinist can do with a chunk of Aluminum or Steel.
    This video will astound you!
    Behold.
    The World's Smallest ... V-12
    A Spanish engineer named Patelo has crafted what he calls "probably" the world's smallest V12 engine -- a labor of love built from 261 aluminum, bronze and stainless-steel pieces that the engineer designed, turned, milled and drilled himself to the tune of 1,200 hours of work.
    In context, that's equivalent to 50 straight 24-hour days.
    (The machine is not for sale, and is dedicated to his grandchildren.)
    The engine, with its 12-cubic-centimeter displacement (from twelve 11.3-millimeter-diameter pistons).
    Runs on compressed air injection.
    https://www.youtube.com/watch?NR=1&feat ... 3KdpzL3Hkk
    GIZMAG feature article extolling this achievement.
    http://www.gizmag.com/spanish-engineer- ... dium=email
    :::::: Spanish -to- English Translations ::::::
    Construimos el ciguenal: Building the crankshaft
    Comenzamos el montaje: Begin the installation
    Montamos el ciguenal en el bloque: Fit the crankshaft in the block
    Cojinete de apoyo del ciguenal: Crankshaft bearing support
    Taques: Tappets
    Arbol de levas: Camshaft
    Cojinete de apoyo del arbol de levas: Camshaft support bearing
    Engranajes de la distribucion: Timing gear
    Volante: Flywheel
    Cilindros: Cylinders
    Pistones: Pistons
    Comprobamos con un taladro que todo esta en orden: Check with a drill that everything is in order
    Culatas: Cylinder heads
    Balancines: Rockers
    Varillas de balancines: Rocker shafts
    Colectores de admision: Intake manifolds
    Colectores de escape: Exhaust manifolds
    Tapa de distribucion: Distribution cover
    Bombas de refrigeracion: Cooling pumps
    Enfriador de agua dulce: Fresh water cooler
    Filtro de admision: Inlet filter
    Pruebas de funcionamiento: Function tests
    Camara lenta: Slow motion
    Numero de piezas/tornillos: Number of pieces/screws
    Horas de trabajo: Hours of work
  2. mtnbikecrazy55
    Re: Just When You Think You've Seen It All!!!
    That is INCREDIBLE.
  3. k-moe
    I ran across that too. My father was a machinist for Freightligner (he started before they had any CNC machines), so I have a huge respect for the art and craft. As awesome as that little V-12 is I like this just a little better; mainly because it runs on fuel.
    Tiny I-4
    Some people might prefer a V-8
    44cc V-8
    And here is a video interview of the builder of that fantastic V-12
    The man behind the smallest V-12
  4. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I marvel.
    Gary
  5. TIMEtoRIDE
  6. Polock
  7. Ejpt
    Ejpt Member
    Springfield, MO
    Very cool indeed
  8. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    the v12 is truly a technological wonder, put that puppy in a blender!
  9. k-moe
    OK, I need to stop looking at videos before I spend my retirement money.
    1/4 scale drag car with 1/4 scale V-8
    I'm tempted to get one of these engines made and put it into a scooter :D It wouldn't be fast, but it'd sure sound good.
  10. skillet
    skillet Active Member
    SW TN
    Came across it before and was AMAZED! Nice to be reminded of it again. THANKS for the additional links!!!
    skillet
  11. RickCoMatic
    I really enjoyed watching the "Process".
    Polishing the Journals.
    Attaching the lower-half of the Big-ends on a Connecting Rod and Piston that he displayed sitting on his fingertip with room to spare.
    The two tiny Camshafts that he held in the palm of his hand were unbelievable.
  12. Massimo33
    Massimo33 Member
    Denver, CO
    That was incredible! I really enjoyed watching him put that together, that was truly an amazing little engine.
    Massimo
