What's wrong with this EBAY listing?
Discussion in 'Hangout Lounge' started by adrian1, Mar 4, 2013.
  1. adrian1
    adrian1 Active Member
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Titanium or Stainless, can't be both.
    Gary
  3. 750E-II_29Rbloke
    South Cheshire, UK
    They'll also fit other models as long as you fit their carbon alloy sprocket....
  4. k-moe
    Ummmm, guys......... XS11's are shafties.
  5. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    Shaft drive
  6. 750E-II_29Rbloke
    South Cheshire, UK
    And they're for sale on ebay Australia from Wrexham, over here in England... much much wrongness!!!!
  7. 750E-II_29Rbloke
    South Cheshire, UK
    Couldn't resist it, I've asked him which sprocket they're for... :twisted:
  8. rocs82650
    Middle Tennessee
    k-moe,
    you got me. Titanium and Stainless aren't the same tho. Can I get 1/2 credit? Nope. Tough professor. Think I might transfer outta' your class before I have to Withdraw, take a Incomplete or FAIL.
    Gary
  9. RickCoMatic
    You are not supposed to know what's wrong.
    You're supposed to think buying those nuts will give your bike super-powers!
  10. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Who wouldn't want to have Titanium nuts!!!
    Although Titanium will be stainless because like stainless steel it forms a passive oxidized barrier that is nanometers thin.
    Another example of a clueless Ebay seller-god bless them.
  11. Folsoml
    Folsoml Member
    Tallahassee, Florida
    My nuts are cast iron.
  12. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    Awesome, post what his response is.
  13. 750E-II_29Rbloke
    South Cheshire, UK
    haha, will do, if I get one...
  14. rocs82650
    Middle Tennessee
    MercuryMan wrote:
    Although Titanium will be stainless because like stainless steel it forms a passive oxidized barrier that is nanometers thin.[/quote]
    LIKE makes it NOT the same. Titanium and Stainless are not the same. Agreed, they will act similiar but while Stainless is the high standard in most applications Titanium is a harder alloy. For me, Titanium drill bits, that'll work; screws, nuts, bolts and washers...Stainless is above average and works great.
    Gary
  15. 750E-II_29Rbloke
    South Cheshire, UK
    I think he meant it will be literally stainless, as in it won't mark or degrade like most materials :?:
    Oh, and the bolts are, apparently, for the REAR sprocket of the XS1100. I should have guessed :wink: lol maybe I should find out what chain he would recommend...
  16. rocs82650
    Middle Tennessee
    I know...I was teasin'.
  17. mtnbikecrazy55
    Gary[/quote]
    Ti is WAY too soft to make drill bits out of.
  18. MiGhost
    MiGhost Well-Known Member
    Did you guys ever consider the drive flange that is bolted to the rear wheel?
    Ghost
  19. TIMEtoRIDE
    Try picking up your "Titanium" drill bits with a magnet !! 8O
    Or don't - it'll burst your bubble :lol:
    some real titanium here
  20. rocs82650
    Middle Tennessee
    mtnbike wrote:
    Ti is WAY too soft to make drill bits out of.[/quote]
    ????...You're teasing right? Bosch makes them, Neiko makes them, Vulcan makes them...need more? I was taught next to diamond laced drill bits Cobalt and Titanium bits will last the longest. Of course one could argue steel and a bit sharpner. :D FWIW, I don't own/buy cobalt or titanium drill bits. I use steel.
    Gary
  21. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    The "titanium" drill bits are not titanium. They are steel with a coating of TiN, titanium nitride. The coating is a thin film on the surface of steel.
    Titanium nitride is far harder than metallic titanium.
  22. 750E-II_29Rbloke
    South Cheshire, UK
    You're thinking off the gold-ish coloured ones? that's Ti-nitride coating & is VERY durable/hard, but once worn out and you sharpen them you're back to a normal drill bit. They do work well though I like them.
    EDIT-: huh, guess we thought the same thing at the same time! :eek:
  23. rocs82650
    Middle Tennessee
    JPaganel,
    No, no, nooooooo. I wanted mtnbike to tell me that. :D
    Gary
  24. mtnbikecrazy55
    Exactly-
    Try making a drill bit from titanium metal, and let me know how that works, lol
    My bike's made out of 3/2.5 Ti and is compliant as can be- great for shock absorption and ride quality, but not something you would want to make a drill bit out of.
    The main benefit of ti is its lightweight and strength, not its hardness.
  25. rocs82650
    Middle Tennessee
    mtnbike,
    You're right. All drill bits have a steel base. That's why I buy steel bits. You're sharp.
    Gary
  26. 750E-II_29Rbloke
    South Cheshire, UK
    I guess it'd be rather like using a blunt steel drill bit of about 10 times the normal length, very slow going & rather springy :wink:
  27. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    How the heck do you fasten your bike in the chuck anyway? :? :?
    :p :p :p
  28. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    Haven't you heard? It's not the size of the drill bit but the motion of the drilling.
  29. 750E-II_29Rbloke
    South Cheshire, UK
    Exactly, slow going & the springier the better! 8O :? :wink: lol
    It's all in the hammer action...
  30. mlew
    First thing that caught my attention is the XS11 does not have any sprockets that need nuts, its a shaft drive bike. The only sprockets are on the cam and they have bolts.
  31. smeagol21b
    smeagol21b Active Member
    hanover,pa
    Didnt you know? Its a new type of metal! It called ti-stainium! Lol! Its light weight,resists corrosion/rust,aluminum oxide and more! It also has all the weight of steel!
