Windshield
Discussion in 'XJ Modifications' started by coastie550XJ, May 14, 2007.
  1. coastie550XJ
    coastie550XJ Member
    Dulac, LA
    Ok, so i have a question, does anyone have this type of windshield.. i'm thinking of getting this one, but i'm not sure.. does anyone have this type or know anyone who does and if so what do you think of it?? do you think its worth getting??
    Thanks!
    oh yea here's the link
    Windshield
  2. Old-Grunt
    Old-Grunt Member
    that looks like my windshield,its ok but the air flow hits right at bottom of my helmit and is annoying,I've tried moving it around a bit and havnt had much luck,if it was a couple inch's taller I think I would like it a lot more
  3. Old-Grunt
    Old-Grunt Member
    coastie,I just went out and measured mine,it is the 15 1/2 tall one,it may work fine for you but I will probly get one a couple inch's taller some day,I sit up straight and close to the tank,(dirtbike habit) if I slide back on seat it isnt to bad,or if just cruseing its ok,but at 70-75 mph it pushes the air right in bottom of my helmit and is annoying,oh I'm not tall either I'm 5"8'
  4. coastie550XJ
    coastie550XJ Member
    Dulac, LA
    that might just work for me, i don't go fast on my bike, i'm a crusersing type of gal, i prefer to take backroads then the highways.. so i'll consider it, going to depend if i can afford it right now.. being a low man in the military don't get paid all that well! thanks Old_Grunt!
  5. coastie550XJ
    coastie550XJ Member
    Dulac, LA
    Oh, also Old Grunt do you happen to have a picture of your bike with the windshield on?? i would like to see what it looks like on a maxim.. thanks!
  6. tonyp12
    tonyp12 Member
    TX
    Coastie,
    I have this exact shield in clear and have experienced similar issues with it as old-grunt. The air hits me at about eye level but the main problem seems to be the air flow around the deflector buffeting my head around. I am inclined to think the shield is not wide enough to block the air.
    I do want to sell mine if you're interested though.
  7. coastie550XJ
    coastie550XJ Member
    Dulac, LA
    hmm well i'm interested thats for sure, how much are you selling it for?
    I'm only 5'4-5'5 and i get buffted by the windshield i have now.. actually not really a windshield but a fairing.. also i want to ask, what kind of helemts do you guys wear? i have a full face helmet.. thanks!
  8. tonyp12
    tonyp12 Member
    TX
    I use a full face. My expectations of this shield may have been too high.
    I was looking for a "highway" shield to block wind going 65-75mph.
    It does the job up to that point then the wind starts to get too agressive for me. If you don't do alot of cruising at highway speeds then it might work for you.
    The one I have is in good shape, only had it on the bike for about 3 rides then decided to take it off. The paint on the nut adjusters is scraped off a bit due to trying every conceivable angle adjustment.
    I'll sell it for $30.00 plus the frt. Can send you pics of it if interested.
  9. Altus
    Altus Active Member
    London, Ontario
    Well I'm 6' tall, wear a full-face, and I'm currently running with a Slipstreamer Spitfire:
    Slipstreamer Shields
    It's pretty nice, though depending on prevailing winds occasionally I do get some helmet buffetting.
    On the same page you'll also see their Cobra shield - I had that one before, and think I actually prefer it to this one.
  10. coastie550XJ
    coastie550XJ Member
    Dulac, LA
    i would be very interested in seeing pictures! thank you!
    also if you would be willing to wait until the first of june, i'll be interested in buying it from you!
  11. tonyp12
    tonyp12 Member
    TX
    I'll PM you, check you messages. Thanks
  12. Old-Grunt
    Old-Grunt Member
    I'll try to get you some pics but it might be a couple days,
  13. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    coastie, I have an 85 XJ700N and have the same windshield as your looking at, it is a bit small for 70 + mph riding. It does keep the wind down for the most part.
    You can see my bike in my avatar
  14. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    We've had this discussion on another forum I belong to. There are over 3000 members, so the issue about wind buffeting comes up often.
    It seems that just about an windshield has it limits as far as protection. There is a nasty updraft that comes up from under them that causes this annoying, head shaking, mustache-tickling-your-nose air flow. Some are worse than others, depending on the size, shape and position of the windshield. If you hold your hand out to block the updraft, you'll notice it comes up around the sides of the gas tank while you ride.
    There are different ways to attack this issue. One is to install "lowers" on your forks which somewhat elliminate most of the updrafts. They are simply clear plastic deflectors that route the wind out of the way. I believe they are Memphis Shades brand. There are chrome ones also sold by National Cycle that look a little better and help elliminate the updrafts.
    I have a pair of the clear plastic ones modifies to mount on the top of my crash bars on my other bikes and I now have a "dead air" space and can almost light a cigarette while riding. I never liked my eye glasses jumping around while riding and the bridge of my nose got kinda sore after an all day ride. This completely got rid of my problem.
    So basically. the smaller the windshield, the less protection. You can experiment with the angle it is mounted and get better results sometimes too. >PD<
