82' Seca Resurrection
Discussion in 'XJ Technical Chat' started by Icebergh, Apr 5, 2013.
  1. Icebergh
    Icebergh New Member
    Minnesota
    I just picked up 82' Seca 650 that has been in a warehouse about 12 years. I hope it is going to work.
    Question for you or ANYONE; should i pull of the clutch cover and crank case cover so that i could spray some sort of soaking oil on things? I am not "that guy" when it comes to motors. However, I am determined to become very comfortable. The goal is to get it rollin down the road for my son's last summer home before shipping of in the Navy.
  2. hogfiddles
    Hey Ecologito........ paging Ecologito........... you have a call on line 3---
    dave
  3. moellear
    moellear Member
    Lima, Ohio
    HUH? 8O phew, you got a long road ahead of yourself if this is how you phrase questions. Start off reading the service manual
    *EDIT* http://www.xjbikes.com/Forums/viewtopic/t=27544.html
    click on the link above to get you started. it has every major important topic you can start thinking about investigating if you don't have a manual currently.
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    And then after you read all that, we'll be here to answer the other 852 questions/problems you'll likely run into.
  5. Icebergh
    Icebergh New Member
    Minnesota
    Now Now, Play nice please
    The question was vague on purpose to invoke all possible suggestions.
    So far I have three responses and no answer and I'm pretty sure the books are not going to tell me what is customary after a twelve year park.
    I am obviously concerned about a proper first start up. I have removed the spark plugs and poured a small amount oil and fogging spray to get things wet. I will turn it slowly by hand and repeat before cranking with the battery. I will drain the old oil and inspect. I will run an "IV" bag of gas to avoid all possible tank and petcock issues. I do intend to do the most complete carb job ever attempted, but only after I know the engine will crank.
    Any friendly words of advice will be welcome
  6. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    I heard someone paged me? Dave?
    Welcome Icebergh, here are the general steps to follow if you want that bike to be road ready AND safe. Before you even start get a Hayes Manual or a service manual for your bike. Once you have something to refer to:
    1.- Check valve shims
    2.- Clean carbs, sync, and tune
    2a.- Do a compression test on the engine
    3.- Replace brake lines, shoes and pads
    4.- Service Master cylinder
    5.- Get new tires
    6.- Service fork seals
    7.- Go from there (you not the bike).
    I would highly discourage you from skipping any of the above steps, if you choose to, you will end up having to do things more than once and/or may end up with a very unsafe bike on the road.
    If you need any specifics on each step try a simple search on the forum or let somebody know. I am going though the same process at this time (maybe more than one bike to be coming back to life).
    Hopefully this helps to get you started because it is also my understanding that once you have done all this you will have a good bike to ride and start servicing as it should.
    You will only try to keep up/ replace/ service everything that was not done to that bike for 30 years.
    Have a great time and keep asking questions (and be ready to play Jeopardy XJ edition).
  7. ecologito
    NASCAR Country, NC
    BTW your timeframe sounds really ambitious but doable if you do not have a full time job or a 6 month old baby. Don't ask how I know that.
  8. 750E-II_29Rbloke
    South Cheshire, UK
    Eco, I'd reverse 2 & 2a, comp test before investing time/money in carbs surely a wise move?
    Otherwise, you've about covered the basics. Now the fun starts 8O :lol:
  9. Icebergh
    Icebergh New Member
    Minnesota
    The bike will not roll anymore than around our housing loop without replacing those rear shoes (and wheel bearing while I'm in there) and a complete front brake rebuild.
    Already bought fork oil...considering these progressive springs everyone is talking about...are they worth it guys?
    My job keeps me away from home for two weeks in the North Dakota oil boom then I get a whole week to tinker at home.
  10. hogfiddles
    Oil boom in the USA? I bet WE'll never feel it.............
    Dave F
  11. hogfiddles
    Dave F
  12. tskaz
    tskaz Active Member
    That's the very short list.
    Shall we start from the top down?
    1. All electrical connections cleaned and greased
    2. Speedo and tach cables lubed or replaced
    3. Possibly new clutch/throttle cables (lube at minimum)
    4. Tank cap seal
    5. Petcock rebuild
    6. Carbs cleaned and possibly replace the rubber bits as well as float valves, etc. then sync and colortune
    7. MC rebuild, new brake lines, caliper rebuild, and new pads
    8. New tires (6 year life and yours are over 12 years old)
    9. Valve shims adjusted
    10. oil and filter change
    11. Inspect clutch, possible new friction discs or full clutch pack
    12. New fuse box (it will eliminate a LOT of electrical problems)
    13. New battery
    14. New plugs
    15. New rear shoes
    16. Change dif fluid
    17. rear brake light switch adjust
    18. New air filter
    19. Remember to use Kroil or PB Blaster on ALL bolts before removal
    20. New bulbs in all signals
    That's the top 20 list, NOT in order of importance.
    Then after that you may run into smaller problems such as leaking tach seal, starter motor brushes, etc. and so on.
  13. Icebergh
    Icebergh New Member
    Minnesota
  14. ecologito
    NASCAR Country, NC
    I remember the ad for that bike (based on your pictures) it was donated to spme sort of non profit and sat in a warehouse, they were asking too much if I recall fora ime that will need quite a bit of work.
    I can't believe you had to hack the fender/mudguard. I would've swap it for you with a chopped one. If you are going to butcher/ replace any parts please let me know, I may be interested or have something for you.
  15. gomk007
    gomk007 Member
    Minneapolis, MN USA 55406
    Congrats!
    I gotta plus the guys on here, they are right on the money with the list of "items" to take care of.
    Ecologito and tskaz are dead on. Between this site and having the FSM my bike is a solid daily rider. I've ordered parts from chacal and search out hogfiddles, he runs a shim pool - both guys have been great to deal with!
    Couple of specific items that I'm REALLY glad I tackled; over winter I broke the carbs apart and replaced the fuel rail seals and the throttle shaft seals. Not as hard as it seems and all of the seals that were removed were practically dust...
    The other item that has made a huge improvement have been front springs and rear shocks. The PO I got the bike from put progressive springs in the front and over winter I replaced the rear shocks. I ended up keeping the stock rear springs, but the difference between the bike on my 2 rides so far has been night and day! One of the best improvements I've done to the bike!
  16. Icebergh
    Icebergh New Member
    Minnesota
    i moved too fast on my son's idea to cut the tail. Gotta slow it down and stay stock for now. He is eager to add clubman bars.
  17. ecologito
    NASCAR Country, NC
    Nothing wrong with throwing mods to your bike and add your own "flavor" to it if that is what you are going for. Some of us are trying to put together a totally stock bike and trust me there are some pieces that because of loose fast sons are really hard to come by (like the fender he just chopped).
    Keep posting your progress.
  18. bigfitz52
    There's nothing wrong with a little "personalization." My "stock" stock 550 Seca and my resto-fied Seca both have low bars, aftermarket shocks, upgraded brakes, H4 headlights and re-done seats.
    My "personalized" bike also has a luggage rack, fork gaiters, a bunch of blacked-out parts, current-style Yamaha turn signals, a recontoured seat, bar-end mirrors and a floating-rotor disc front brake. It still looks pretty much "stock."
  19. Icebergh
    Icebergh New Member
    Minnesota
    Started the Carbs
    <iframe class="imgur-album" width="100%" height="550" frameborder="0" src="http://imgur.com/a/yq7iC/embed"></iframe>
    http://imgur.com/a/yq7iC#13
  20. quebecois59
    Icebergh,
    Judging by the dark brownish red spots I saw near the butterflies shafts on your last picture, I'd say your seals are shot. You may be in for a complete rebuilt.
  21. GrooveJunkie
    GrooveJunkie Member
    Linden, MI, USA
    Thanks for the picture library. I'm getting ready to pull my carbs for cleaning/rebuilding/Stage-1 jetting, and this will be a great help.
    given the amount of space opened up, I've decided that there are some peripheral tasks that I'll be doing after the carbs come off (cam tensioner adjustment, etc...).
    looking forward to your continued progress.
  22. gomk007
    gomk007 Member
    Yep, gotta say I agree with quebecois59, I skipped doing a complete teardown (breaking the rack apart), but after 2-3 months had leaking fuel rail seals that sidelined the bike yet again.... I did the fuel rails seals and throttle shaft seals and no more problems, plus the bike idles better now. Of course this gives you the opportunity to get the valves in adjustment and a nice carb syncing.... Do it once do it right and you won't have to remove the carbs from the bike for a while. I bet I could pull the rack out blindfolded by now...
    PM me if you want help...
  23. Icebergh
    Icebergh New Member
    Minnesota
    Here is a first look at my carbs on the bench
    <iframe class="imgur-album" width="100%" height="550" frameborder="0" src="http://imgur.com/a/jgek6/embed"></iframe>
    http://imgur.com/a/jgek6#0
  24. bigfitz52
    Interesting. That was the primary issue with the heretofore untouched carbs on my 650R. Bike fired right up, but peed gas all over itself almost immediately, and not because of stuck floats.
  25. Icebergh
    Icebergh New Member
    Minnesota
    Here is a picture record of "Breaking the Rack"
    <iframe class="imgur-album" width="100%" height="550" frameborder="0" src="http://imgur.com/a/KCsbM/embed"></iframe>
    http://imgur.com/a/KCsbM#0
  26. Icebergh
    Icebergh New Member
    Minnesota
    I have removed absolutely everything from my carbs (82' 650 seca) except two air jets so that i can dip them and maybe soda blast if they get dark. I got the jets from under the banana plate on top side but have not yet been successful at the two that face the air box. They have huge orifices so they are easy to clean. A thread on this site said i had to remove them for dipping. Why? So ultimately my question is did i need to remove the others and do i need to remove these? I still do not know how to add a pic to this
  27. 750E-II_29Rbloke
    South Cheshire, UK
    I think the 2 supplementary air jets (in each carb throat, facing the airbox) will be fine staying. I have no idea why you'd need to remove them for dipping unless the dip was corrosive to brass (normally it's just rubber you need to worry about).
    You need to remove the other jets & the emulsion tubes for cleaning so that you can thoroughly clean any residue and on the e-tubes clean out the tiny air holes.
    On the pics, I'll post a picture under here & you hit the "quote" button & study the URL and IMG brackets, add the same brackets to your hosted pic's address & it should show up :)
  28. Icebergh
    Icebergh New Member
    Minnesota
    alrighty then....time to dip then. I think I understand; I do not "attach" a pic directly from my computer file, but rather "redirect" to my cloud pics, in may case, Imgur. I have been doing small albums on there to track my progress. It will be nice to just add a photo or two when asking questions. I'll give it a try.
    Also here is the album: http://imgur.com/a/34AEQ#0
    [​IMG][/img]
  29. 750E-II_29Rbloke
    South Cheshire, UK
    Cool that seems to work :)
    See the brass part in the actual centre of the carbs? (the part the main jet screws into when you look in the underside) They need to be tapped out to clean them properly.
    Some will just fall out through the top of the carb by themselves, others (the really dirty ones usually) will be stuck & need a gentle tap from underneath. Be careful not to mar the threads for the main jets when you tap them, and when they're out make sure the *tiny*, smaller than a full stop . holes in the sides of the tube are all clear ;)
  30. hogfiddles
    If you're dis-assembling the carbs to clean, pull the last two airjets and clean them ANYWAY. What's the difference in a couple more turns of a screw driver? Sheesh. The air still goes through the passages, and if you're gonna clean, CLEAN. As in "the Church of CLEAN".
    How many times have we had people on here with carb issues that have had just the tiny little speck of dirt be the problem? Too often. That's the way it is.
    But......if you want to leave them in, go for it. It's your bike. If it were me doing the carbs, EVERYTHING is taken apart. EVERY piece is cleaned.
    YMMV,
    Dave F
  31. bigfitz52
  32. Icebergh
    Icebergh New Member
    Minnesota
    Did somebody SHEESH me. I have never ever done carbs and if you see my picture album it is obvious I have taken this further than most already. I wasn't being lazy on the two screws; my best fit of 50 screwdrivers was just a bit thin so I did not want to chew them up. One of the better carb write ups on this site said "IF I absolutely must remove them like when dipping..." This person also attends the church of clean and said "IF". Anyway, when selecting a sacrificial screwdriver to grind down, I gave it another attemp after kroil did its thing and they practically jumped out...so now it is truly naked and the emulsion tube was already out but the picture looked brassy from varnish
    [​IMG][/img]
    I kinda don't want to dip'em cuz they are p r e t t y clean on the outside but...it is Sunday so...church of clean...baptism by chem-dip.
  33. Icebergh
    Icebergh New Member
    Minnesota
