Tire sizes
Discussion in 'Hangout Lounge' started by beardking, May 17, 2007.
  1. beardking
    beardking Member
    This question will be slightly off the XJ topic, but still relates to motorcycles. If your stock tire is a 110/80/18, how would it affect the bike to go to a 110/90/18? I've been looking at tires for one of my other bikes (99 Nighthawk 750) and the front tire is a 110/80/18. For some reason, this does not seem to be a popular size, but the 110/90/18 is easier to find.
    Now, before someone starts suggesting certain brands of tires that have the stock sizes, I've actually got my tires on order and I got the OE replacements. I'm just looking for information for future use.
    Thanks in advance
    Beardking
  2. fozziebear
    fozziebear Member
    Cleveland,Ohio
    The 90 will be a taller tire and will throw off the speedometer and possibly affect handling. To get the approximate diameter of a tire multiply the width by the aspect ratio, multiply by two, divide by 25.4 to convert to inches then add rim diameter.
    110x.8=88 , 88x2=176mm , 176*25.4=6.929+18=24.929.
    110/80-18 tire=24.929" diameter
    110/90-18 tire=25.79" diameter
  3. beardking
    beardking Member
    Fozzie, I actually made an Excel file that does the calculations for me (I was using it while I was looking for tires).
    So, how would it affect the bike if you went up to a 90 on the front and say an 80 on the back if the back is originally a 70?
    STOCK
    110/80/18= 24.92913386
    140/70/17= 24.71653543
    Non OEM:
    110/90/18 = 25.79527559
    140/80/17 = 25.81889764
    I guess I'm just used to looking at truck tires where bigger is better as long as it doesn't rub anything. ;)
