HOW TO CHECK YOUR TIMING
Discussion in 'XJ Technical Chat' started by fishhookxj, Apr 15, 2013.
  1. fishhookxj
    fishhookxj Member
    FLORIDA
    i was just wondering on my xj750 how do you check timing
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Simple answer, you don't ;) Ignition timing is effectively "fixed" (TCI deals with advance/retard)
    Of course if you mean valve timing, there's marks on the cams & caps but you shouldn't have any problem there if you haven't had the cams out?
  3. fishhookxj
    fishhookxj Member
    FLORIDA
    Gotta love the simple questions and answers thanks again life saver.
  4. bigfitz52
    TRUE. However,
    It doesn't hurt to verify the functionality of your TCI occasionally---
    Just throw a timing light on it, and watch it advance as you rev it up.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    Very good point, for that you'd hook up to number 1 lead Fitz? (well 1 or 4 fire same time, but 1 is nearest).
    I doubt the TCI is the issue with the firing on one cylinder problem though, and trying to use a timing light on an engine running that badly may not be practical... I assume this is why you asked about timing, Fishhook?
    Perhaps a compression test would be useful in this case?
  6. fishhookxj
    fishhookxj Member
    FLORIDA
    I did a compression test all show up in 145s and 150s i mean a valve shim job wouldnt hurt when i get there but since im doing all the ignition stuff i figured i test timing after i got here running on all fours. I think the one cylinder is due to my coil and also i had it wired backwards lol, not to mention when one plug was pulled there was no gap at all.
  7. 750E-II_29Rbloke
    South Cheshire, UK
    cool at least it's mechanically healthy enough to run :) that's pretty damn good numbers you got there...
    No gap at all isn't good, plugs tend to open over time. Are you sure they're the correct ones? What's the code on them? :?
  8. fishhookxj
    fishhookxj Member
    FLORIDA
    ill have to double check got em from advance auto, i might of bent them at one point when i had the engine out my last engine is gone i replaced it with this one was in a storage unit with only 3000 original miles so i grab it did a compression test and got lucky. Im going to put in all new plugs cause one looks different anyways idk if the mixed my plugs or not.
