  1. k-moe
    I rode it, and rode it, and rode it....until the wind started gusting to 40MPH. I prefer to save the leaning over for when I'm going around a bend.
  2. 750E-II_29Rbloke
    South Cheshire, UK
    Amen to that! been blustery here lately too :?
  3. tcoop
    tcoop Active Member
    South Weber, Utah
    Painted the tank.
    it still needs to be cleaned up (got some finger prints). Next will be the front fender and cleaning and repainting the engine and headers.
  4. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Changed oil and oil filter, need to do some cosmetic work on her this year.
  5. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    cleaned and lubed speedo cable. Still have a slight ticking in the speedometer itself. Waxed the tank and side covers and buffed. Went for a nice 20 mile ride
  6. CapnRedbeard
    CapnRedbeard Member
    London England
    Just about to visit the garage and give it a clean, still waiting for new exhaust, but planning a ride tomorrow as no work..! but not supposed to rain. So at least i'll have some fun.
  7. boldstar
    boldstar Member
    ABERDEEN.SCOTLAND
    30 mile run a polish up a coffee cig then a smile ace.....roll on the summer
  8. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    Last weekend, shoveled in front of the garage for the 4th time this month in hopes it would dry enough to take the bike for a run so I can change the oil. No luck so far, and most snow coming tonight so doesn't look like it will be until May.
    This winter was replacing front brake lines with SS, replaced fusebox with new blade styles, new headlamp, misc cleanup and some detail painting.
  9. XJOE550
    XJOE550 Active Member
    Inverness, FL
    First time I've done anything to the SECA. So I guess, I can mark this date as the official start of the restoration. Will only work on rust removal for now and figure out what can or can't be saved. So just trying some new things for removing rust. Tried using Marvel Mystery Oil and let it soak on the left muffler and shock for a couple of days. Then used a Scotchbrite pad. Worked ok, but had to pull out the drill with the scotchbrite adapter to use on the shock springs. Worked ok I guess. But the cheapest and favorite way to remove rust from parts is to let them soak in white vinegar for a week or so. I'm in no rush, I have pleanty of time. So first sign of progress. But only did the side that is visible when I walk by every day.
    Before cleaning:
    After cleaning:
  10. 750E-II_29Rbloke
    South Cheshire, UK
    Pulled carbs and boots one last time (to make & install new paper gaskets for the boots), double-triple checked the float's wet-set again while they were off, still spot on :)
    Installed them and thumbed the starter to discover it starts and runs even better than before.... Amazing, I couldn't detect any leaks anywhere & it was running great already, I only made the gaskets because it's right that way and the difference is noticeable to my ears!!!
    So now I get to do my running sync and colourtune again for that perfect touch... and have to replace the fork seals that "were replaced" by the P.O. since the right one is now pissing oil after a ride round the block.
  11. broberg
    broberg Member
    Sweden, Östergötland
    I snapped an exhaust stud clean off.. I'm happy
  12. cbrozefsky
    cbrozefsky New Member
    Chicago
    Finally, disassembled the whole front brake system, and will be rebuilding it all, with SS lines. Just need to get the caliper piston unstuck, and I have plenty of ideas from the forums here on how to do just that.
    Since I was going to have to order a caliper rebuild kit from Chacal, I figured I would do the valve clearance check and order the shims at the same time. This bike has 10k miles on it and I'm sure has never had a clearance check done. All valved but one are tight. Exhaust are all tight by 0.02mm or so, and intake range from 0.01mm to 0.7mm! So, new shims for all.
    I've been waiting to do this work for over a year. I ordered the parts for it all, but didn't want to have the bike unusable during the riding season. Got a Suzuku V-Stromg (2011) and that gave me a chance to rip into the xj, but...it got cold, and my garage space is unheated.
    Got the bike with 3k, put 7k on it in the last two summers, including a Canada tour -- love it and can't wait to get the front brake rebuilt, which is the last of the safety system to be done (new rear brakes, new shoes, new headset bearings all done already). Once I have the valves in spec, I'm gonna continue down with the rest of a tune-up, and then some cosmetics.
    I was contemplating selling it, but it's much more fun to have a bike to work on. I have to at least dip into the dark arts of carb cleaning and syncing. I figure by then I'll be too attached to give it away.
  13. 750E-II_29Rbloke
    South Cheshire, UK
    Went for a pleasant, if fairly short, ride. First time I've been further than pushing distance from home on the bike & it's pretty darn good. Nice and smooth...
  14. jpacman
    jpacman Member
    East Central Vermont
    Spring is coming achingly slow to New England this year and so I have been afforded several non-riding Saturdays to clean up niggling little problems.
    1) Sputtering at take-off led me to look into the carb intake manifolds for a leak. Checked with unlit propane. Yep, well there's yer problem. Boots cracked, fixed with Super Black ATV and silicone tape, made new gaskets (there were none previously!!!), reinstalled carbs, RUNS GREAT!
    2) Rechecked the rear brake. Still sound.
    3) Fixed dash warning lights for fuel and battery with resistors. Worked. Ha, ha, ha. No more red lights for me!
    Hope the weather prediction for this Saturday holds.........65 and sunny!
  15. 750E-II_29Rbloke
    South Cheshire, UK
    Just reminded me, I've got to "attend to" the red warning light slap bang in the middle of the dash that comes on above 80km/h (about 50mph). Really quite annoying that... :lol:
  16. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    so doing my forks on my YZ250 today, gettin ready for a big ride trip with about 10 other people down in kansas. anyways, took one fork apart and come to find out the compression valve in it had rattled apart :( so all these pieces were floating around in my forks :lol:
    The other valve was intact (thank god) so i pieced the one together by taking apart the intact one, these puppys aint big parts, as you can see with the dial calipers pic. but there is a total of 22 separate pieces making them up. oh and one other small detail, NO manual will have an exploaded view of compression valves, (cant even find one online) its a closely guarded secret :) so im waitin for thread lock to dry on these then gonna reassemble, oh and one other small detail my dirtbike is a 1997 but has 1998 forks on it :lol: ....through me off.
  17. 750E-II_29Rbloke
    South Cheshire, UK
    Wow looks a right PITA to assemble from floating bits! 8O
    In the middle of second oil change then going to ride a little if the weather holds up
  18. jpacman
    jpacman Member
    Used Scotchbrite and spray bottle magic to shine up the engine cases. Polished the fenders and pipes while I had the gloves on. Hosed it off, and hey, there's a good looking bike under all that winter grime!
    70 and sunny - bet your a$$ I'm goin' for a ride!
  19. 750E-II_29Rbloke
    South Cheshire, UK
    Finished changing oil, went for a nice ride out for an hour and a bit, got back completely buzzing with happiness. Bike feels great, loving it 1000% right now :D
    Be even better when those carbs get properly synced again, that's for Thursday weather permitting.
  20. wazimoto
    wazimoto Member
    MN
    After a long winter of projects, I changed the oil again, did a final assembly, checked everything over again, and RODE IT!!!!!!!!!!! 8O 8) :lol:
    It ran like an absolute champ! Couldn't be happier :D
  21. Foolber
    Foolber Member
    actually wasn't hard since i pulled out the other one as one whole piece. just took him apart and re-assembled according to how the intact one looked :) just tested here with a bit of wheelies in the back yard, stiffer than an I-beam in winter!!! (but still plush, just how i like it) Now to wait till this weekend to see how she does on the jumps! also she has VP 111 octane in her for this trip and shes lovin it.
  22. RickCoMatic
    Battery.
    Pre-flight.
    Pulled battery.
    Topped-up with Distilled Water to just peeking at the Top of the Line.
    Charged Battery 2 Hours at 4 amps.
    Might need a New Battery.
    Then, ... I washed the Monte Carlo.
  23. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Borrowed some proper Race Pro carb sync sticks (the old mercury type) from my manager at work. Did a sync as she sat, just for giggles, then busted out the YICS blocker. Ran better synced with yics blocker in.
    Of course, when you take the YICS block out and button everything up, it runs a touch worse :( grrrrr...
    Better than it was tho, I may have to investigate further tomorrow.
  24. johnnyx
    johnnyx Member
    london ont
    Did an oil change-installed a new gas cap seal-installed a guardian bell-and rode like a wildman.
  25. Orange-n-Black
    Memphis Area
    Trying to put the carb rack back into my son-in-laws 700. Now I remember why I hate airboxes.
  26. Foolber
    Foolber Member
    Gave it a hug, talked to it a bit...
  27. k-moe
    Rolled it out, saw lightning in the distance, rolled it back in. Spring is finally here.
  28. maxim82
    maxim82 Member
    Farmers Branch, Texas
    Installed 8 brand~spanking new shims!(Len you rock!) I have more tweaking to do but it's all good.
    Listening to KSCS (Dallas) while I review my awesomeness!
    Yep, I'm awesome.
  29. RickCoMatic
    Well, ...
    I took-out the Battery after turning the Ignition ON and having the lights barely glow enough to say they were on.
    It lasted two seasons of pulling-into the garage, hitting the Kill Switch and forgetting to turn the key off.
    More than once.
  30. Cuchulaain
    Cuchulaain New Member
    finally on the road....
  31. 750E-II_29Rbloke
    South Cheshire, UK
    Fri-: Stripped & rebuilt forks/anti dives & installed correct amount of oil to not blow the seals like John Haynes wants me to do (and like the P/O did do!).
    Sat-: Waiting for the weather to clear up & roads to dry before the covers come off and we take a ride... :) (yes this one's a dry days only machine! Never thought I'd own one 8) )
  32. johnnyx
    johnnyx Member
    london ont
    Shined her up and rode for two hours-what a rush-twenty degrees here today-awesome.
  33. jpacman
    jpacman Member
    Got up early and changed the oil, removed the foot pegs to move them back (lubed pivots), put on the seat pad I made last night, checked fork and tire pressures, and hit the road.
    Did 285 miles in the (almost) Green Mountains. There's still snow up here in the hills. Bike felt solid and ran great! Can you say "Super Premium"? Always, please.
    Awaiting delivery of new valve cover gasket so I can do a valve clearance check.
  34. Orange-n-Black
    Memphis Area
    Airbox boots are too old and hard (soaking in hot water didn't help), they split and tore while trying to put the carb rack in. So now its pvc airbox time because it's cheaper than buying original air boots.
  35. Foolber
    Foolber Member
    moved it around the garage after i got back from a buddys trails down in kansas. heres a couple of pics, we managed to get a truck down in them after uprooting some trees lol. love the hills down there, 2 gear im about 17ft in the air 8)
  36. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Reset my pilots to 3 turns out and resync'd. I can get the sync really good using yics block, removing the tool and plugging the yics, sync is off.
    I'm not sold on having to block the yics to sync. What's the point when they aren't blocked while running normally, and it throws the sync off after the block is gone.
    Either way, went for a nice 200 km ride, she ran strong, idle can fluctuate a bit tho. When I say that, I mean it idles high or low depending on wether I'm sitting downhill or uphill at a stop. *shrug*
  37. hogfiddles
    I woke up the 700 airhead this afternoon. She crawled out of the den, a little bleary-eyed, but after I poked her with a 10min prod with an 8amp poker, she roared to life and we spent the rest of the afternoon tooling around.
    Dave F
  38. 750E-II_29Rbloke
    South Cheshire, UK
    Sunday-: Quick & dirty spray up of the cooling fins and sanded back the edges to metal again, removed fairing to fix loose instrument panel & repair trip/clock set button, checked forks holding air/oil.
    Rode 100 miles, started raining 25miles out & stopped 10miles from home, wind was fierce & temp dropped to 4c :( Spent the rest of the day recovering feeling in my fingers, right shoulder & hips... Was nice to get for a decent ride though, bike never missed a beat & was the nicest thing on Cat & Fiddle while I was shivering with a smoke in the corner! :D
    Mon-: Still a little achey from the windchill, going to give her a good wash shortly.
  39. Kilted_to_the_Max(im)
    Duluth, MN
    Oil change over the weekend, now waiting for the 4 ft deep mud to go away in our 100 ft driveway so I can get on the road.
  40. motors-guitars
    motors-guitars Member
    Noblesville, IN
    been a week but i changed the oil and got both new tires!
  41. jpacman
    jpacman Member
    Tore apart the gauge cluster to get at the sticky tachometer. What kind of fun is that?!? Followed other strings and suggestions to use a little good machine oil on the pivots of the needle. Worked great!
    Weather has been just fabulous. Did 200 miles in the mountains with a few buddies this weekend.
  42. mtnbikecrazy55
    Got these in the mail today - Progressesive Suspension 412's - Going to be a nice upgrade to the worn out old stockers! :D
    Made in the USA!
    More pics to come and I'll post a thread with a ride report once i get them on, looks like i need to either swap out or track down one bushing :/
  43. frankenbiker
    frankenbiker Member
    gobles michigan
    Took out my 9mm and shot it, but for the first time ever the gun didn't fire. so Frankie lucked out.
    Back to the drawing board I guess. LOL
  44. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    let me know how those shocks work mtnbikecrazy55 i want a set for my seca .
  45. ElkHavenSeca
    Sedro woolley wa
    this is what i did with my yamaha today , yesterday , and the previous week before that , work starts again thursday !
  46. KrS14
    KrS14 Active Member
    St Marys, Ontario
    *jealous*
  47. ElkHavenSeca
    Sedro woolley wa
    They do look nice . cannot wait to hear how they ride !
  48. broberg
    broberg Member
    I fitted the progressive rear springs and shocks the other day..
    And new needle bearings for the swing..
  49. mtnbikecrazy55
    What kinda paint did you use ^^
    looks nice!
  50. broberg
    broberg Member
    My frame? It's powder coated, satin black.
