knocking sound
Discussion in 'XJ Technical Chat' started by leadboots, May 18, 2007.
  1. leadboots
    leadboots Member
    aylmer ontario canada
    at idle my bike has a knocking sound. is that normal?
  2. DMoreyXJ550
    DMoreyXJ550 Member
    Columbus, Ohio
    knocking is never normal bud.
  3. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Answer the door.
    Then check your motor!
    Bur seriously; describe "knocking"......
    Is it an actual "knock" or a "ticking" sound?
    Use an empty paper towel tube and isolate the source........top end or lower end?
    Lower end= bad
    Top end = fixable.
    Inquiring minds want to know!
  4. leadboots
    leadboots Member
    i am gunna take a video of it really soon
  5. leadboots
    leadboots Member
    well i cant take a video of the knocking but i did find out that when i pull in the clutch the knocking goes away but as soon as u let go it starts knockin. sounds like its coming from the bottom end
  6. Chared03HD
    Chared03HD Member
    Fergus Falls, MN
    What's your ideal set at (RPM's)? From what I've heard/read and seen 1000 is a good number.
  7. leadboots
    leadboots Member
    idle is at 1050
  8. mainexj550
    mainexj550 Member
    maine
    mine has similar symptoms, including the clutch action changing the sound. I think the sound is coming more from the rear of the case on mine.
    I found that running an idle around 1700 makes the noise less noticable.
  9. RickCoMatic
    Cut a piece of fiberglass rod from an orange driveway marker and probe the engine.
    Listen to the end of the rod while you touch the other end to areas that you suspect the knock is coming from.
    You should listen to the engine and have someone work the throttle and disconnect a plug wire and put it back on ... for all four plugs.
    You will hear a knock above the regular rotational and valve train noises.
    If you probe for a knock ... and DON'T hear the knock happening in the usual rotational and machine noises ...
    Look for an exhaust leak.
  10. leadboots
    leadboots Member
    i think it could be low octane fuel . i only had alitte 87 octane then i put in some 91 octane gunna try some octane boost. hopefully that helps. i have another problem too. im not sure if its oil or gas gettin in the exhaust pipes. but after about 10 mins of running her the pipes start smokin. i dunno if its a leak from the engine . the smoke comes from where the exhaust goes from 2 to one on the right side.
  11. leadboots
    leadboots Member
    well im pretty sure i fixed the knockin sound. put some nos octane booster in it adds sixs points the the octane level
  12. RickCoMatic
    I'm not at all surprised. About this time, last year, I was getting gas in New England, that was causing my bike to knock. I wrote it up because it was pretty severe and I didn't want anybody having a problem elsewhere.
  13. leadboots
    leadboots Member
    thanks for the help guys. now can someone help me with the smoking exhaust?
  14. XJturbo
    XJturbo Member
    NW Ohio
    You could have some worn rings and burnin' a little oil, if it's possible for you to do a compression check I would do it. Oil used to leak a little on my old maxim from around the oil pressure switch on the bottom of the motor right above the exhaust collector.....it would get hot and start burnin' the oil and smoking quite a bit till it all burnt off.
    -Nick
