vibration?
Discussion in 'XJ Technical Chat' started by livingdeadlyxj650, Apr 19, 2013.
  1. livingdeadlyxj650
    livingdeadlyxj650 Member
    kimberling city MO.
    Dang it feels good to be on a properly tuned xj. Runs like omg fantastic. Rides pretty nice as well. And I thank you to every one here that has helped me to get to this point. Anyways! This is what's going on. Right at 60 mph. Im getting a vibration through the seat of my pants and through my grips. Feels like a gigantic cell phone vibrating. But goes away at 58 or 61. Stange stuff. Any ideas guys?
  2. k-moe
    Ride at 65. Inline fours buzz. Perfectly normal behavior for your engine
  3. mtnbikecrazy55
    Yup, xj's harmonic range per say.
    It's usually around 4500 -4700 rpm, not speed dependent.
    Now that you have it properly tuned up, kick it down to 4th gear and hear the sweet sweet sound of a properly tuned xj at 6k :D
  4. livingdeadlyxj650
    kimberling city MO.
    Oh wow? So everyone experiences this? And its not detrimental to anything? Im having a hard time letting the bike wind out. Makes me cringe. Im used to v8 rpms lol
  5. waldo
    waldo Member
    San Jose, Ca. 95125
    Think Ferrari not Chevrolet
  6. bigfitz52
    Channel your inner Ralf Schumacher.
    ALL XJ's have a "harmonic" RPM range, as pointed out above.
    That being said, the effect can be greatly minimized by making sure the bike is truly in tune: valves in spec, float levels accurate, vacuum sync-ed to perfection, etc.
    The more out-of-tune the bike, the wider the RPM range and more noticeable the "buzz range."
  7. livingdeadlyxj650
    kimberling city MO.
    Check check check and am doing tom the vac sync. Its the only thing I lack. But it runs supreme as is. Lol my buddy is lending me his gauges tom. I just rode it and yeah it is in the rpm range.cool beans. Thanks guys.
  8. k-moe
    One more thing of note. Make sure to check the bolts and bushings (on rubber-mounted engines) for your engine mounts. Excessive looseness will alter the "buzziness" that you feel, usually not for the better.
  9. Polock
    drill holes in the crankshaft :)
  10. livingdeadlyxj650
    kimberling city MO.
    LOL that member helped me do that earlier that week. Drilled out the end of every lobe on the cam aswell ;) ill check the mounts not a bad idea.
  11. RonWagner
    RonWagner Member
    A harmonic is defined as when the natural response equals the forced response; it is what makes a bell ring, a radio work, and bridges collapse. Engineers try to design engines so the harmonics are not in the normal operating range; unfortunately the XJ and a lot of bikes have such a broad rpm range the harmonic is going to be somewhere. The range they chose is a bit annoying but they chose it for a good reason. The faster the engine runs the greater the stretching and compression forces on the rods and these forces are greatly amplified at resonance (the first harmonic) and can potentially worse at the second or third. Harmonics have multiples so there is goung to be a second one at double that rpm which is just outside of redline. Therefore they chose the lowest rpm range possible while still having only one harmonic. Conversly if they picked 4000 rpms for their first harmonic it would have been more mild but the second one at 8000 would be much more destructive.
    Bottom line: They designed the engine and frame to withstand the stress of the harmonic but it is best not to cruise in it; there is simply more wear going on. Just pass through it enjoy the feeling at 8-9K.
  12. RickCoMatic
    Put some Rubber Wedges between the Cooling Vanes.
    Our Bikes came with them.
    Washing dislodges them, ... and you don't even know.
    Copyright YAMAHA Motors ©
    I'm pretty sure they are available from Len.
    Click on XJ4Ever.
  13. Mike82mxm
    Mike82mxm Member
    Ste,Annes,Manitoba,Canada
    that makes me laugh!!!!! sooo funny just outta nowhere
  14. Mike82mxm
    Mike82mxm Member
    I had a 83 xj 650 bad vibes @ 100km/h but @ 101km/h they were gone.I was always told don't worry about it.so i never did
  15. waldo
    waldo Member
    San Jose, Ca. 95125
    I have seen pictures of fellows who have drilled holes in their crankshaft and as far as I am concerned my crankshaft is fine without any additional holes in it. The one whole put in it by ( fill in the appropriate divine spirit that your religion says done it) is fine with me. Praise all that is Holy to you and yours. Amen
  16. k-moe
    That particular vibration is audible, and occurs from idle all the way to redline (on my bike anyway). It's caused by the length and placement of the cooling fins. Vacuum hose works just as well as the wedges to silence the ringing.
  17. livingdeadlyxj650
    kimberling city MO.
    Yeah mine Defo still has most of the blocks. And its Defo just a physical vibration. Lol
  18. RickCoMatic
    I'd bet the Crank was "Balanced" during the Build.
  19. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    You can also fill your bars to minimize the buzz or use BarSnake, and put rubber washers where your pegs meet frame. Proper tuning, good oil, and E'thing tight to specs will also minimize. If someone would make some nice polyurethane bushings for our bikes that would be ideal. Last resort ride at higher rpms!
  20. RickCoMatic
  21. mtnbikecrazy55
  22. livingdeadlyxj650
    kimberling city MO.
    Shit if my xj had 30k less miles on it. Id be on it lol.
  23. cdilmore
    cdilmore Member
    Pittsford, NY
    Today was my first ride on my "new" '82 XJ650 - and I experienced this very phenomenon. What a relief to find your post and learn that it's not a flaw! XJ Community rawks!
  24. moperformance
    moperformance New Member
    Same here! I bought my 82 xj650 a year and a half ago and at first I thought the clutch was out of balance because at 4800 to 5200 the vibration was very noticeable. And if it was the engine it was going to come apart soon. 18,000 miles later it still buzzes at the above rpm and i either ride above it or below so it's not coming apart anytime soon.
    I ride 50 miles round trip to work everyday and it's been a joy. :D
