'87 Radian project
Discussion in 'Other Motorcycles' started by scott-s, Apr 22, 2013.
  1. scott-s
    scott-s Member
    Rock Hill, SC
    For the headlight? yes, just waiting on that pictail to show up so I can splice it in. Tali/brake light works. Turns light up, but don't flash (LED), but the bike isn't running yet. I'll figure that out.
    I plan on using some existing wires to connect the gauge package.
  2. Orange-n-Black
    Memphis Area
    No, the angle grinder.
  3. scott-s
    scott-s Member
    Rock Hill, SC
    Cleaned the chain and gave the chain guard a coat of semi-gloss black today.
    I also dropped off the seat at my favorite local guy. I was just going to leave it with him while I worked on the project, but he called two hours later and told me it was done! Stock pattern in heavy duty, marine grade vinyl.
    I also studied the wiring diagram and the instructions for the Danmoto and I believe I have that all figured out. The only variables are maybe needing a resistor for the tach signal and figuring out which wire on the oil level unit I can use to light up the oil pressure light on the Danmoto. I plan on getting all that wired up in the morning.
  4. spinalator
    spinalator Member
    Regina, CANADA
    great progress!
  5. Captainkirk
    Captainkirk Member
    Northeast Illinois
    A great take on an old classic!
    Fantastic progress! I just love watching an old derelict come back to life!
    Keep up the good work!
  6. scott-s
    scott-s Member
    Rock Hill, SC
    Drilled out the head of a bolt (man, that thing was hard!)....
    Epoxied in the magnet....
    ...and made up a bracket for the Hall Effect sensor. I would have liked for it to have been on the RH side since there's a holder in the fender for the speedometer cable, but the LH side fork has the pinch bolt and that was a perfect place to hold the bracket. Not sure how I could have mounted it on the RH side.
    The bracket will be painted black and I plan on cleaning up the forks a bit when the wheels are off to have the tires mounted.
    I also wired up the Danmoto and everything that I can check without having the bike running seems to work.
    Got a great deal on a clean tank, so that's on the way, and my mufflers should be here by Tuesday. If I weren't on massive OT at work, I could probably ride this thing by the end of next week. :evil:
  7. scott-s
    scott-s Member
    Rock Hill, SC
    Pulled the wheels today in anticipation of my new tires. Took the opportunity to clean up around the swing arm...
    ...and pull the forks. I changed the fork oil to 20W for a little firmer front end.
    I also stripped the old clear coat and sticker residue off, lightly sanded the forks with a ScotchBrite pad and clear coated them again.
    One done, one waiting..
    Much better!
  8. scott-s
    scott-s Member
    Rock Hill, SC
    My mufflers also showed up today.
    Got them temporarily mounted. I want to get the wheels back on and the suspension compressed so I can figure out the hangers. I'm going to have to bend/shorten the hangers just a bit.
  9. k-moe
    Having worked with that very type of hall-effect sensor for several years, I feel compelled to ask; Did you use thread locking compound on the jam nuts? If not, do so now. Looking very nice so far.
  10. scott-s
    scott-s Member
    Rock Hill, SC
    That was just for mock up. It will be securely mounted when I reassemble the front end.
  11. scott-s
    scott-s Member
    Rock Hill, SC
    I finished up the muffler installation today. I had to modify the hanger bracket slightly.
    Now they're on. It's a nice, tight fit. The factory trim parts on the side cover up the header/muffler joint and make it look really nice. They clear the swingarm nicely, etc. Really happy with the look and the sound.
  12. scott-s
    scott-s Member
    Rock Hill, SC
    I did manage to hear it run today.
    The Good:
    *The engine sounds GREAT. No bad/funny noises, really smooth, no leaks, etc.
    *The exhaust sounds really good, too. It's much more mellow than I was expecting, but still sounds meaty and aggressive.
    * The Danmoto gauge seems to have the right resistance for the tach to work. Just need to program the tire size in so the speedo will be correct. Oh, the oil light worked when I drained the oil, too, so that's good to go.
    * The charging system is working properly.
    The Bad:
    The carbs are still leaking like hell. They're not responding to adjustments as well as I wish they would. I have to decide what to do about them next. I guess they're going to require a full disassembly to fit new O-rings. I'm also very suspect of the pins that the floats fit on. I tried sanding them smooth, but whoever was in there before me marred them up and I'm wondering if the floats are sticking.
    Here's a quick vid:
    http://www.youtube.com/watch?v=A_5v3tz6 ... e=youtu.be
  13. bigfitz52
    If it has Mikunis and you didn't replace the o-rings on the outside of the float valve seats, they may be the cause of your leaking.
  14. scott-s
    scott-s Member
    Rock Hill, SC
    Cleaned out the tank using "The Works" toilet bowl cleaner method. It's spotless now and just waiting on paint.
    I also picked up my carbs from Rick at http://oldskoolcarbs.com/ .
    I know Rick personally (heck, I could walk to his shop from my house!) and I can't recommend him enough. The O-rings between the carbs were shot, and he also found a problem with the new bowl gaskets I had just installed. The float levels were way off as well. He also "dressed" the three good IMS screws and they move like butter now. I can't wait to get these back on the bike.
    This bracket is usually in the way of the idle mixture screws, since they're plugged from the factory. We trimmed it a little bit, but Rick fixed that up as well.
  15. scott-s
    scott-s Member
    Rock Hill, SC
    Getting closer! I was actually able to ride it for the first time yesterday. Runs GREAT, with no issues so far (other than a pinched O-ring on the oil filter that leaks a tiny drop of oil every now and then. I'll fix that soon).
    I haven't hooked up the speedo yet, so I don't know how many miles I rode it, but I've only been around the neighborhood so far. No real miles to check for the intermittent cutting out issue the P.O. had.
    I'm beginning to think it was a combination of filthy carbs and a dead, dry battery.
    http://www.youtube.com/watch?v=n-oIuVWy ... e=youtu.be
    No...I know you all LOVE it, but I won't be keeping the stallion on the tank. Paint and body is coming up soon.
  16. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Hey, scott-s. It's been two weeks since your last post. How are things coming on the Radian? I bought an 89 two months ago and like the things you've done. Might steal some of your ideas. Especially the tail light mods. That fender extension the license hooks to looks honky. Do you know of a café fairing for the square headlight?
  17. scott-s
    scott-s Member
    Rock Hill, SC
    I've seen various fairings on ebay for a square headlight.
    I don't have the speedometer/odometer hooked up yet; I'm waiting on my buddy to flip the cable holder around on the fender so I can hook up the Hall Effect sensor. I guess I've put close to 200 miles on it so far, though. Zero issues and runs GREAT!
    As soon as that's done, it's time for bodywork and paint. That can't happen soon enough, as far as I'm concerned. It took balls to ride up to a local bike night with that horse on the tank!
    I did swap out the bars today. A friend commented that he'd like more narrow bars and I have to say he's right. The Super Bike bars were super comfy, but they did seem a little wide. I also had a heck of a time finding mirrors that would work AND look cool.
    I had this set of Rizoma MA001B bars and put them on this morning. Looks much better and still feels nice. They're a tad lower and quite a bit more narrow than the S.B. bars.
    I finally broke down and bought a bar-end mirror. Cycle Gear had real aluminum (vs. plastic) mirrors on sale. Got this folding version for $25.
  18. bmarzka
    Looking great. Done anything new? I replaced the handlebars on mine with ones that look similar to yours. Did you have to play with angle so the controls clear the tank when turning?
    Found a site that sells bike fairings called AirTech. Check it out.
    And personally, I like the horse on the tank.
  19. scott-s
    scott-s Member
    Rock Hill, SC
    Rode her for about 115 miles the other day. Took her out on some really twisty roads around a local lake. Big Fun!
    I pulled the bodywork off and started sanding. Dropped some of it off with my buddy. Hope to attack the tank tomorrow.
    I changed the oil and replaced the pinched O-ring on the filter housing to stop that little drip.
    Other than that, just waiting on paint and then final assembly and programming the speedometer.
  20. scott-s
    scott-s Member
    Rock Hill, SC
    Got the tank stripped, dents repaired and primed. Block sanded it in three stages. Here it is with the guide coat on, just before final sanding and color.
    We also prepped the tail and fender. The hole for the speedo cable was filled because I'll be running a Hall Sensor and it's mounted on the opposite side.
  21. scott-s
    scott-s Member
    Rock Hill, SC
    Painted, waiting to be buffed out. It may appear a little violet in the photos, but it's a dark, midnight blue.
  22. bmarzka
    Looking super! Can't wait to see the finished product. Giving me a lot of ideas.
  23. scott-s
    scott-s Member
    Rock Hill, SC
    And...she's done! Paint is finished and Hall Sensor installed for the speedo.
  24. bmarzka
    OH MY GAWD!!! That is absolutely beautiful. Well done.
    Just one question. Did you upgrade the front brake system?
  25. scott-s
    scott-s Member
    Rock Hill, SC
    Nope. It's all stock. The P.O. had a new master cylinder installed. I adjusted the rear brakes. They work fine. I thought about installing braided stainless lines, but the brakes work so well right now I'll probably just leave them be.
  26. k-moe
    What are the date codes on those lines?
  27. scott-s
    scott-s Member
    Rock Hill, SC
    No clue. Probably original to the bike.
  28. pjk_xj700
    pjk_xj700 Member
    Northeast Lower, MI
    Very Nice.
  29. k-moe
    Change them.
