9 digit vin converted to 17...help plz!
Discussion in 'XJ Technical Chat' started by Seca23, May 13, 2013.
  1. Seca23
    Seca23 New Member
    So i have an 81 seca 750 and finally almost roadworthy. i have seen others hadas tgis converted also. my 9 digit vin is 5G2-003244. please help very much aporeciated!
  2. lostkause
    lostkause New Member
    ny
    what is the reason you need your vin converted? If it is to get it on the road then you can call the insurance company and give them the vin they will be able to enter it on their and then just fill out the forms at your local DMV and you should be good to go. I just had to do this to my 82 maxim. but the next day it caught on fire. lol
  3. bigfitz52
  4. maverickbr77
    maverickbr77 Member
    Lowville, New York
    was bored so here you go JYA5G2000BA003244 might want to check my math with the link fitz provided.
  5. Seca23
    Seca23 New Member
    i need it converted to get on road but also road get local pd to run vin check. thanks for the conversión. can anyone confirm thats correct? thanks a million
  6. mlew
    The correct VIN is the number stamped on the steering head, it does not matter if it is 9 or 17 digits. You don't want to end up with a different number on the title. Some bikes did have a 9 digit VIN number in 1981. The autos went to a 17 digit # in 1980, it took a few more years for bikes to catch up.
  7. Seca23
    Seca23 New Member
    yes i understand that. but for pd to run vin it has to be 17 correct?
  8. maverickbr77
    maverickbr77 Member
    Lowville, New York
    might depend on where you are, but the 9 digit is the actual legal vin that all records should be found under.
  9. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Not necessarily. His bike has a high enough serial # that it could put it into early 1981 build time, which Yamaha would have still been using the shorty VIN on the steering neck.
    However
    The new VIN system was still being implemented well into 1981. My 650 was built in 10/81, but still was stickered and titled with the 17 digit VIN, while the shorty VIN was stamped into the neck.
    Just because that sticker is missing 32 years later, we can't assume that it was always registered with the shorty VIN.
    The best thing to do in this case is to have the PD run both shorty and full VINs.
    The maths are correct, btw.
  10. Seca23
    Seca23 New Member
    thanks guys. ill have them both ran tomorrow. when i go to register can i just use shorty vin? im in ga if it matters
  11. tskaz
    tskaz Active Member
    That depends on what the PD tells you. Whichever VIN they have a record for will be the one you need to use to file for title.
  12. Cafe_Guy94
    Cafe_Guy94 Member
    Ridgecrest, CA
    Could you help me figure out my vin? I'm having the same issue. My shorty vin is 5N8-028105. Its a 1981 xj650 maxim. The sticker on the other side is the 17 digit vin but is too faded to read.
  13. k-moe
    TECH TOPIC: Model ID and VIN's
