81 650 Starting Problem?
Discussion in 'XJ Technical Chat' started by Tat2demon, May 16, 2013.
  1. Tat2demon
    Tat2demon Member
    Sioux Falls, SD
    I don't know if this is normal or not.
    When starting my 81 XJ650 Maxim, it takes about 2 seconds for the starter to respond after pushing the button. If it doesn't start right away, each button push takes a little longer than the last until finally after 4 or so pushes, nothing at all happens. If it sits for a minutes the starter will turn again.
    I don't know if this is a built in "safety" feature for the starter or if something is wrong. I took apart the starter button and kill switch and made sure all the contacts are good and clean. I don't know where to look next.
    Thanks.
  2. moellear
    moellear Member
    Lima, Ohio
    When I did have my 650 (same year) running and used as my daily rider couple years ago, this similar situation happened to me quite often. I always thought the gremlins didn't want me to fire up the bike; joking aside I'm curious what the possibilities could be as well. Sorry not much help; I just ignored it since I figured the starter was fine.
    I'll be waiting for responses as well, since I never took the courage to ask.
  3. bigfitz52
    If it's not the button, or a handlebar grounding issue, then the next place I'd look would be the solenoid, followed by the starter itself.
    Assuming a fully charged and tested-good battery, that is.
  4. Tat2demon
    Tat2demon Member
    Sioux Falls, SD
    Yeah the battery is fully charged and relatively new. Ill check the solenoid later tonight when it cools off a bit.
  5. bigfitz52
    DO NOT simply assume it's "fine." Get it fully charged and have the auto parts store load test it. You might be surprised.
  6. Tat2demon
    Tat2demon Member
    Sioux Falls, SD
    Yep did that a few weeks ago. Everything is good as far as the battery is concerned. Is there a relay somewhere for the starter I should also check? I was out there a few minutes ago for something else and started it. I noticed a click like a relay when it started but when it wouldnt start I heard nothing.
  7. hogfiddles
    My 650 always had a lag...... never was an issue, I knew what it would do, and never had a problem. For me, it was that the button was wearing out.
    Dave F
