Valve cover gasket
Discussion in 'XJ Technical Chat' started by Joseph, May 18, 2013.
  1. Joseph
    Joseph New Member
    I was curious if i can use a silicon gasket maker instead of a gasket. I'd use a real gasket but the nearest parts store had closed for business. If i had to get part i'd have to get online.
  2. Captainkirk
    Captainkirk Member
    Northeast Illinois
    In a word, no.
  3. Tat2demon
    Tat2demon Member
    Sioux Falls, SD
    Many of us on the XS11 forums use RTV for the valve cover with no problems.
  4. jpacman
    jpacman Member
    East Central Vermont
    No, no, no. This is one place not to cheap out. If you use RTV and it doesn't seal, you're going to have oil everywhere. Also, RTV will make future forays into the valve train that much more difficult since you'll have to scrape all that gunk off when it leaks, which it will.
    Clean both surfaces well, use gasket sealant on the valve cover, install the new gasket to the valve cover, a bit of silicone-based grease to the now-adhered gasket (the mating surface to the head), replace the rubber washers on the valve cover bolts, and reinstall the valve cover.
    If you do this right, it will never leak and you will have easier access to the valve train. There are lots of other strings on this subject. Read up.
  5. bigfitz52
    IF it's a YICS motor.
    If it's not, this wouldn't apply. If it is, those are critical.
    At this point we don't even know what bike we're discussing; however the advice given so far is solid: NO.
    YICS or pre-YICS; neither will work well just using RTV for the valve cover gasket.
  6. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Just did my Maxim over the winter. Why temp fate with questionable process and future clean-up issues. New gasket and valve cover bolt washers with proper torque. Not a drop of oil leakage!
