updates on my 81 xj650 turbo project
Discussion in 'XJ Modifications' started by Isaacson06, May 19, 2013.
  1. Isaacson06
    Isaacson06 Member
    Des Moines IA
  2. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Man, that's a bunch of creativity to say the least!
  3. Orange-n-Black
    Memphis Area
    Nice welds. Really like the intake manifold.
  4. Isaacson06
    Isaacson06 Member
    Des Moines IA
    thanks guys hope the intake manifold works lol plenum is big for this engine hoping for the smaller turbo this year to take up the plenum volume lol
  5. Proximal
    Proximal Member
    ATL, Ga
    Very nice welds. I can't wait to see more. You need to make a video when it is complete.
  6. Orange-n-Black
    Memphis Area
    Is it just the pic or is there a pin hole in the seam weld between cylinders 2&3? You'll need to make sure there aren't any leaks in that manifold or you'll have problems.
  7. mcamaj
    mcamaj New Member
    New York
    Amazing work, off topic can i asked about your instrument cluster. What are you using? Looks like something modern off a R6 or close to it? Do you have details on that, how it works and what works???
  8. farmer
    farmer Member
    what size turbo is that??? what were you using before? When did it spool up before??? What size header primaries are they? 1.5 sch 40 stainless?
    Looks real good.
  9. Isaacson06
    Isaacson06 Member
    Des Moines IA
    That's a koso cluster there universal cluster it has everything from shift light to fuel gauge but the things that work on mine are rpm/mph/water temp/oil temp/shift light I think that's it but it does alot more I paid I want to say 310$ shipped for it
    Looks real good.
    This is a 13b turbo this year witch has a 5cm exhaust housing witch is I think is a 41 a/r but a way smaller turbine wheel from my 14b last year with a 7cm housing 49 a/r last years spool times sucked way to big of a turbine and housing and also the turbo manifold last year was 1 1/4 and this year I've made a 1" sch 10 stainless manifold witch the inside is .957 in size so that will up volosity pressure inside the manifold and help spool times.
    Last year I ran 9psi and seen maybe 5psi in 1st and full boost in rest of the gears. I need to get my go-pro vids from last year at the track up so u guys can see it go
  10. farmer
    farmer Member
    interested in the vids for sure. how quick was it?
    also, one other thing... Can the front forks compress all the way without the wheel hitting the turbo or the intercooler?
    and why did you go from individual throttle body to a single plenum? what TB is that from?
  11. Isaacson06
    Isaacson06 Member
    Des Moines IA
    ive compressed the shocks as far as i can while riding and doesnt hit anything
    the throttle body deal is that i didnt really like all that crap shoved in that tight spot looked like crap and plus ive had this idea since i built it so i said hell with it lol and i do alot of honda automotive work so i used a b-series throttle body its 60mm
  12. Isaacson06
    Isaacson06 Member
    Des Moines IA
  13. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    where is the flux capaciter? lol awesome mods!
  14. Isaacson06
    Isaacson06 Member
    Des Moines IA
    its in there look real close lol
  15. skylrk62
    skylrk62 Active Member
    Illinois
    What was your best time? I watched your YouTube vid & it looks like you took the hayabusa out on the start. Did you end up beating him? Do you think you bike can break into the 10's? I'm Thinking about going the turbo route with a 900 & wondering what percentage hp gain I could get with it?
  16. Isaacson06
    Isaacson06 Member
    Des Moines IA
    all complete time to lay down the miles before the snow lays down
    My brother did the paint work
    Fuel pump and battery
    a little vid my buddy likes when i rev it up lol
    http://s114.photobucket.com/user/isaacs ... d.mp4.html
    gauge setup
    http://s114.photobucket.com/user/isaacs ... 7.mp4.html
    skylrk62 you asked how fast its gone last year i rand 1/8th mile only and first time ever lunching a bike on the track and rand a 7.8@92mph but it wasnt intercooled so by the time it hit 3 to 4 gear it was heat soaked this year the bike just keeps pulling in any gear because of the intercooler funny thing is it actually cools the engine temps down when i beat on it lol
    also the busa came around me at the end he won
  17. skylrk62
    Illinois
    I sent you a PM.
  18. Noffy07
    Noffy07 New Member
    Fort Lauderdale
    very nice!
  19. 68vistacruiser
    68vistacruiser New Member
    Southern California
    Since the day I first owned my 83 turbo seca I dreamed about pumping it up some. I still wonder about a 650 maxim frame with a 900 seca motor turbocharged. I see a lot of turbo parts on ebay now and wonder just how easy it could be done now, except for the lack of 900 motors. Nice job on the welding and the creativity! Didn't see, but did you do a chain drive conversion on it?
  20. Isaacson06
    Isaacson06 Member
    Des Moines IA
    nope still a shafty
  21. skylrk62
    Illinois
    Hey Isaacson06,
    I found that spare port manual link for ya. It's for the megasquirt, but it works with the microsquirt as well.
    spare port settings
  22. RickCoMatic
    I got a 900 Plant to sell.
    I had to pull the Jugs to replace Rings in the 2-Hole.
    It's still tore-down.
    But I have everything but the Gaskets, 2-Hole Std Rings, Wrist-pin Retainer Clips.
    Comes with 2 Head.
    1 - fm the Plant.
    1 - Bought and sent-out for R&R
    PM me for details.
  23. Isaacson06
    Isaacson06 Member
    Des Moines IA
  24. Helltime
    Helltime Member
    Des Moines, IA
    Wow I hope to see this out running around some time, nice bike, looks great!!
  25. Isaacson06
    Isaacson06 Member
    Des Moines IA
    heltime i see your in des moines too im out all the time riding see you around
