Any one Identify this tool?
Discussion in 'Hangout Lounge' started by SilentRaven, Jun 1, 2013.
  1. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    this came with the bike it was in the box above the tail light, along with a lock chain ( that matches my key!) and a few old registrations and such. any one have an idea of what it is/does? does it even have anything to do with motorcycles?
  2. Polock
    well you don't need it to work on a XJ. looks like some sort of pliers
  3. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Walnut cracker?
  4. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    thats what i thought at first but it is way to flimsy to crack any nuts, lol
  5. bigfitz52
    The ends appear to be made to lock into something and the rounded part is too imprecise to be anything more than a handle.
    If the ends were shaped differently I'd say it almost looks like a car radio extraction tool.
    It's NOT a Yamaha tool.
    Good fortune on finding the chain lock though. It's not uber-practical (kinda too short) but it's neat to have the one that matches your bike.
  6. JPaganel
    Minneapolis
    Actually, to me it looks like the ends are supposed to be tied together. Seems like a funny kind of a hose clamp.
  7. quebecois59
    Could it be used to hold both ends of a opened chain close to each other while putting the linkage back on?
  8. mlew
    Nut cracker? The PO must have liked nuts to carry one.
  9. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    my original thought was something for the chain, as the ends do lok like they would fit between the links of a chain, and the join at the top looks like a mini chain linkage as well.
  10. Polock
    if that fit around the airbox tubes to pull them back out of the airbox it would be a 100$ tool
  11. mikethecamera
    mikethecamera New Member
    North Wales
    That looks like it fits on the helmet lock on the side of the seat. Has th PO made a custom holder to go through his helmet face opening?
  12. scrubby
    scrubby Member
    bevent Wi
    Looks like a lock of some sort. Looks like it clicks in to a paddle lock bottom.
  13. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    could be... funny thing though im not even sure if i have a helmet lock... at least ive never noticed it before, are they removable? maybe its gone?
  14. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    SOLD!
  15. mikethecamera
    North Wales
    On the left side of the bike under the seat (round where the clip is to lift the seat) the lock is normally on the side panel. (That's where it is on my xj550 anyway).
  16. bigfitz52
    On the 550 Maxim, the seat lock is bolted to the frame on the left side, just in front of the shock mount. It's doesn't stick thru the sidecover like on the "Seca" styled 550s.
  17. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    yup dont have one! just compared my pic to other pics fo 550s and im not seeing one on mine, ill check for real once i get home. So maybe it is some sorta makeshift helmet lock???
  18. mtnbikecrazy55
    Does it fit into the lock?
  19. k-moe
    It looks similar to a bicycle lock (minus the lock) that a friend of mine had in Jr. High. Have you contacted the PO to see if he knows what it is? Maybe he stashed it and forgot about it.
  20. pbjman
    pbjman Member
    Algonac, MI
    It is an alien probing device!!
