New Tank time
Discussion in 'XJ Modifications' started by mmcgee, May 28, 2013.
  1. mmcgee
    mmcgee Member
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Your going to have issues with the width of the double backbone on the xjs fitting a lot of custom tanks. This leads to major surgery to switch to a single backbone or to widen the tunnel on the tank. Either that or you have to sit the tank on top of the frame. You are going need to move mounts or build custom mounts in all likely hood as well.
  3. mmcgee
    mmcgee Member
    Yep. I'm seeing that. However, that may be the best of limited options.
  4. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    All tank swaps I've seen have involved major surgery..... with that being said, how much for your old tank? :)
  5. cutlass79500
    lawrenceville georgia
    If your not a good fabricator those tanks are gonna sit way to tall on top of the backbone.
  6. 82750xj
    82750xj New Member
    I put an 81 xs 1100 tank on mine. Just hammered the tank a little underneath to help sit a little lower . Turn out alright, no major surgery to the tank.
  7. Orange-n-Black
    Memphis Area
    You can put a V-Star 650 tank on it with little to no mods.
  8. hogfiddles
    Uh....not in my experience. I bought a 650 v-star tank to try. The tank is too tall, too wide, and too low on the bottom. the bracket for the dash cluster protrudes as well.
    I have not figured out a way to make it sit evenly without interfering with something, et. Other work is in the way right now, so will get back to that SOMEtime.
    dave Fox
  9. lo_zarro
    lo_zarro New Member
    Italy
    I fitted a Suzuki gsx550es tank
    I had to create New rubber holders And i used a metal sheet to build The rear part to fit it in The rubber next to The seat..
    Maybe not a very good explanation in My bad english!! :D
  10. schmuckaholic
    California
    It was good enough to get your point across. :)
  11. Orange-n-Black
    Memphis Area
    Hey Dave, which bike did you try it on?
  12. hogfiddles
    1985 xj700 airhead.
  13. Orange-n-Black
    Memphis Area
    Well I finally found one of those posts with the V-Star tank mod.
    http://www.xjbikes.com/Forums/viewtopic/t=30745.html
    This one is a 700, I think the other was a 750. Your right about the tank being too wide at the seat. What about a Fazor or Radian tank? You may just have to make something fit. Harley split tanks could be made to fit, would need to cover the middle gap though. J&P Cycles had a set for $125.
  14. hogfiddles
    Yeah, that looks like the 650 vstar tank on there. I'm sure he did quite a bit of modding to get that to fit therre, too. I'd be interested in seeing what was actually done besides just rotating the horns. It's tough to tell.....I'm wondering if there risers handlebar risers. A set of XV110 tripple trees with THOSE risers would give good clearance---I'll have to play with that possibility a bit....
    Dave F
  15. Henkies
    Henkies Member
    The Netherlands, Europe
