Lost my keys
Discussion in 'XJ Technical Chat' started by ryancdossey, Jun 14, 2013.
  1. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    So my keys were flushed by my adorabe nephew. My only set of keys. What are my options?
  2. hogfiddles
    1st, check to see if the drain trap is accessible.......................and also, fish around the trap inside the toilet...they may be sitting there....
    2nd.....take the ignition switch off, and whatever other things you may have used another key for--and take them to a locksmith. If he's a good one, he should be able to either make you a new key, or re-core the cylinders for new keys.
    3. Buy replacement switch, cap, locks, etc....
    Dave F
  3. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I actually still had my key code on my ignition switch assembly. I was able to just order a pair of keys for my bike with the numbers and it didn't cost much at all. In fact, I believe I ordered them off of Ebay. There are many places that will cut you keys if you have the numbers.
  4. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Where could i see that?
  5. hogfiddles
    get to the back of your ignition switch......it should be on the the back of it--you may have to play around with light angles, etc...... to be able to read it.
    Now, here's a trick that works often for me.......if you can't read it, take a good digital picture of it. Then put the picture on your computer and do some editing with changing the contrast, color, polarity, saturation ,etc......often it is possible to enhance things enough to finally read it. Granted, just as often it doesn't work......but I always take a shot at it--and can get results.
    Good luck,
    Dave F
  6. schmuckaholic
    California
    This can be seen here:
    Clean and lube the ignition switch
  7. jchalo99
    jchalo99 Member
    Connecticut
    OK i got a gas tank from a buddy of mine, he broke off the key half way in the lock... (so not all the pins are moved yet) so i got the tank for 5$... but anyway the locksmith said all he can do is drill out the lock. are there aftermarket gas caps?
  8. hogfiddles
    Is it possible to get a piar of needle points against the sides of the remainder of the key? Maybe you can pry it out. If not, then your key smith is correct........drill it out. Then, use a screwdriver the turn the dogs at the bottom of the cylinder. Open the cap, remove the mounting bolt. Now, lift the cap assembly off. Get there are plenty of forums about replacing/restoring lock cylinders, so that's easy.
    As far as replacing the whole thing, any 550, 650, 700, 750 maxim gas cap, 650rj seca, or 81-86+ virago cap will interchange. These caps are NOT rare, they're readily available, plentiful, and not expensive.
    Dave F
  9. jchalo99
    jchalo99 Member
    Connecticut
    sweet thank you.
  10. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    1. Tie a rope around adorable nephew.
    2. Explain what the keys looked like.
    3. Flush the adorable nephew, keeping hold of the other end of the rope.
    4. PROFIT!
  11. ryevans21
    ryevans21 Member
    North Iowa
    I enjoy the underpants gnomes reference (south park)
  12. jpacman
    jpacman Member
    East Central Vermont
    Yep. Had both issues. No keys when I bought the bike because one remaining key was broken off in the tank lock. Removed ignition lock and got key made. Then drilled and replaced the gas cap with a matching drum. Shiny, new chrome to boot!
