Xj900F
Discussion in 'XJ Technical Chat' started by xjs10, Jun 16, 2013.
  1. xjs10
    xjs10 New Member
    Lincoln UK
    Can anyone tell me if a XJ900f engine will fit straight into a XJ750 SECA frame, im thinking of fitting one into my trike. Looking at the mountings they look the same......but looks can be wrong
  2. Bushy
    Bushy Active Member
  3. MiGhost
    MiGhost Well-Known Member
    The 900, and 750 use the same engine mounting points. You will need to get the TCI, and carbs with the engine also.
    Ghost
  4. quebecois59
    Are you talking about the 1983 Seca 900RK and the 1984 Seca 750RL, or any Seca 750?
  5. xjs10
    xjs10 New Member
    Lincoln UK
    Talking about a 1989 xj900F engine into a 1982 xj750 Seca.........both UK models if that helps
  6. MiGhost
    The 900F, and the 900R use the same engine. There will be no problems with bolting it into the 750RJ Seca frame. They all use the same mounting points.
    Make sure you get the carbs, and TCI with the motor.
    Ghost
  7. hogfiddles
    Look through the Information Overload hour stuff, too. Len has done some nicely detailed write-ups on just what you need to do for various engine swaps.
    Dave F
