Signal light question (Not LED)
Discussion in 'XJ Technical Chat' started by cappy1983, Jun 19, 2013.
  1. cappy1983
    cappy1983 New Member
    So i purchased new signal light for my 82 XJ550. I hooked them up and they don't flash. The lights use 1156 bulbs so its the same bulb as stock. Could it be my flasher has stopped working and just needs to be replaced? I don't have any tail/brake lights on the bike right now but i am not sure if that affects the signals. Any ideas?
  2. RickCoMatic
  3. kyle10149
    kyle10149 Member
    Durand, Wisconsin
    Are both the signals front and rear (both sides) lighting up or just on per side
  4. cappy1983
  5. cappy1983
    When i turn the signal to the left both the left ones light up and stay lit. When i turn the signal to the right both the right ones turn on and stay lit. The turn on correctly they just don't flash
    Is that what your asking?
  6. kyle10149
    kyle10149 Member
    Durand, Wisconsin
    yeah that what i was asking sorry it was kind of confusing.
    mine did the same thing to me this spring i threw a new flasher at it and it works great now. If the switch turns them on and off then it is working and if the bulbs light up then the wiring circuit is likely ok i would guess flasher
  7. RickCoMatic
    Just for something to do that will take you less than 20-minutes ...
    Check the length of your Alternator Brushes.
  8. Erman
    Erman Member
    Oslo, Norway
    I was going to suggest not enough charge on the battery, but someone already said bad flasher...
  9. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I'd guess weak battery as well.
  10. bigfitz52
    The test for that is how they behave when the bike is running above 2K rpm.
    If they flash fine when the bike is running above 2K rpm, but won't flash at idle, you do indeed have a weak battery. The XJs charging system doesn't "kick in" until you hit 2200 rpm or so; below that it's all on the battery.
    So if you're testing them in the garage with the bike not running then most likely it's simply a weak battery. And it doesn't have to be very weak.
  11. cappy1983
    Thanks for the replies. The bike is a bit of a project so i'll get it running again and see if they work then. And if that isn't it i'll change out the flasher.
  12. kyle10149
    kyle10149 Member
    Durand, Wisconsin
    Good plan I overlooked the batt. I always work with it on the charge a thing ny dad always pushed
  13. open1mind
    open1mind New Member
    Hello all- dont post often, but I read the informed opinions here all the time.
    I have a similiar problem to what you describe above, ie- dont flash reliably at idle. I just ordered a service manual to help me troubleshoot, and I will hook the battery up to a charger tonight. My question- what should the bike be reading at idle? Just a flat 12V? Mine is a mint 82 750 Maxim
    thanks
