ground cable
Discussion in 'XJ Technical Chat' started by Foolber, Jun 19, 2013.
  1. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    so im about done with my bikes work i have been doing for the past 7 months (should of just started a damn thread for this thing) and i cant remember were the ground cable attaches, i know i could just find a spot on the frame but i like to keep them as OEM as possible.
    could anyone give me a good pic of an 82 XJ750J (or similar) ground cable. (i think this one went to the motor but its been so long i cant remember lol
  2. RickCoMatic
    The Ground Cable is attached to the Engine just behind the Starter.
  3. Foolber
    Foolber Member
    i thought it went in that area, but i also have a cable running from the motor (attached behind the starter) to the frame, should i attach it to that same bolt? then technically it would be grounded to the frame....
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    It should go from the engine to the neg on battery.
  5. Foolber
    Foolber Member
    yep rgr that! thanks!
