Petcock leaking
Discussion in 'XJ Technical Chat' started by Maxxwell311, Jul 17, 2013.
  1. Maxxwell311
    Maxxwell311 New Member
    Michigan
    There appears to be gas leaking from the front of my petcock. Any suggestions as to where I can find a rebuild kit for my '82 Seca 550?
    Thanks for any and all help!
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    Click on the banner at the top-right of the page. Fastest way to get the parts. If its leaking just around the top mating surface, you probably don't need to rebuild the whole thing, just get that gasket. Might as well do it all while you're at it...
  3. Maxxwell311
    Michigan
    Thanks for the info Lacucarcha. I will check out the link. Any idea on why I've used a 1/2 tank of gas in only 70 miles??
  4. kleraudio
    kleraudio Member
    Erie, CO
    Not sure on the Seca's but I use about a whole tank at 100 miles.....
