Carb cleaning adventure/questions thread!
Discussion in 'XJ Technical Chat' started by kleraudio, Jul 24, 2013.
  1. kleraudio
    kleraudio Member
    Erie, CO
    Hey there guys, making up this thread because I start cleaning my carbs tonight. I'm terrified of these things but with you guys here, I'm confident I can get it done!
    First question, the brass (i think they're brass) slides look pretty stained, what do you guys recommend I use to clean them up? sandpaper? What grit? I bought some WD40 and some carb cleaner (valvoline)... looking forward to getting in this thing tonight and the next few nights!
    I also plan on doing the clunk test, I remember rick saying scotch brite strips, I'll have to see if can pull up that thread again. I don't have a dremel.
    Here she is right after pulling:
    You can't see the stains on the slides in this pic, but they're there!
  2. Polock
    Slides are anodized aluminum, dont sand them. Forget the stain. Do the bore with scotchbrite, lightly.
  3. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Do you have a small torch and an impact screwdriver?
    The screws on old Japanese bikes are made from metal the hardness of which is somewhere between warm butter and play-doh. They are also often stuck because of decades of dirt and corrosion. Add the Philips vs JIS issues to this.
    Now that you are properly nervous, here is what to do about it: Be very careful getting screws out, use impact if you have to, and heat if it gets really bad. Be careful heating the screws that hold the "hats", there are rubber diaphragms under there, and if you cook them, they are not cheap to replace.
    Once you do get them out, replace them, preferably with stainless Allen bolts. You can go the Cadillac route and get a screw kit from Chacal, or you can go the Yugo route and get them one at at time from ACE hardware, Fastenal, or some place similar.
  4. RickCoMatic
    I use "Needle-nosed Vice-Grips"
    I get a good grip on the Head of the stuck Screw and give the Needle-nosed Lock-on's a whack with a Hammer Handle.
    Throw-away rusted or bunged-up Fasteners.
    INVEST in a Stainless Steel Allen TOTAL Replacement Kit.
    XJ4Ever
    or
    Ebay
    The price of a Complete Kit is a tremendous saving rather than buying the Fasteners ala carte'.
    http://www.ebay.com/itm/YAMAHA-XJ650-XJ ... 0385403305
  5. RickCoMatic
  6. DaveT174
    DaveT174 Member
    Onslow, IA
    I bought my stainless kit from that seller. I have nothing but good things to say about the seller, BUT the kits ship from France. It was close to three weeks before I got mine.
  7. kleraudio
    kleraudio Member
    Erie, CO
    Yea that looks great and all but I can't wait three weeks to ride! Hopefully these screws come up and out nicely. I'll replace them the next time I do a carb clean. Season is almost up and I've barely ridden my new bike!
    I don't have an impact driver, but I have sort of gotten good at using a hammer and screwdriver. Slight leftward pressure on screwdriver then I tap with a hammer/mallet, seems to work so far :) I think someone has been in here recently so hopefully the screws come out with ease, we shall see, I start tonight.
    Rick, that article you posted, I've already read that like 10 times and printed to have next to me when I do this tonight! where can i get these scotchbrite strips? Going to "attempt" to clean carb #1 tonight. If that goes well I'll go to # 2 if time permits....
  8. kleraudio
    kleraudio Member
    Erie, CO
    Oh and while I've got the carbs off the bike, I want to seal those cracked up intake boots. Someone said black RTV high temp... I went to the store yesterday and saw black rtv but nowhere did it say high temp....
    What exact product am I looking for? I'd like to put a coat on per day to really seal them up.
    Also, can I spray the outside of the carb rack with carb cleaner to clean up the exterior? I don't want to ruin any gaskets here.
  9. DaveT174
    DaveT174 Member
    Onslow, IA
    I don't have an impact driver either. What worked well for me was a t-handle bit driver. It lets you really put your weight on it and apply torque more easily. Also, JIS screwdrivers or bits are the way to go but I found that "Pozidrive" bits are very similar.
  10. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    I used a regular screwdriver. actually I used screw extractors and replaced all the screws with new ones.
  11. kleraudio
    kleraudio Member
    Erie, CO
    Screw extractor aye? I'll have to go to home depot on lunch. So you just take the screws into home depot and find ones that compare?
  12. jmilliken
    Dillsburg, PA
    yep. I felt no need to spend $ ordering JIS screwdrivers when most of the screws were rusty + questionable anyway
  13. kleraudio
    kleraudio Member
    Erie, CO
    cool, I'll pull some screws and head to home depot on lunch tomorrow and buy a whole set of each...
    What screws do I need besides the 4 that hold the top and the four that hold the bottom?
  14. kleraudio
    kleraudio Member
    Erie, CO
    what kind of scotchbrite do I need and where can I buy it? I've never purchased scotch brite.... want to get it on my lunch break so im prepared for later.
  15. Polock
    do you plan on breaking the rack? as in separating the carbs ?
  16. kleraudio
    kleraudio Member
    Erie, CO
    Polock, no I don't plan on breaking the rack.
  17. Polock
    then don't spray too much around the springs between the carbs, seals are in there.
  18. bigfitz52
    And whatever you do, DON'T SUBMERGE them.
  19. kleraudio
    kleraudio Member
    Erie, CO
    Cool, definitely wasn't planning on submerging them! Ok, I'll just leave the outside a little dirty as I don't need to be messing with seals.... You're talking about the springs between the carbs with the phillips type screw driven through them?
    Just picked up some 800 grit wetodry sandpaper to do the bores where the piston is, going to use wd40 as lube per Rick. Also grabbed some Hi temp RTV to do the boots while the carbs are off the bike. Do I just push some out and work them into the cracks? How many coats are we talking?
  20. RickCoMatic
    Using Standard Tools on the Carb Fasteners is what tears them up.
    Many a good rack of Carbs have been transformed into Parts Carbs because someone didn't use the right screwdriver trying to remove Pilot Mixture Screws.
    A sloppy fit, ... and the "Slot-wings" move without the Screw Body.
    Then they break right off and will send the Carbs under the Bench gathering dust.
    Believe those who have traveled down the road of Stuck Jets.
    You get ScotchBrite (Gray) Pads at TruValue.
    Paint Dept / Sandpapers and Abrasives Asile.
    After doing a "Fill-in Job" on Intake Manifolds, ... I do a Emery Board Festival smoothing-over the repair.
    Hillbilly touch-up: Magic Marker.
    Advanced: Liquid Electrical Tape.
    (Don't use the "Dabber". Cut it off the cap. Use an old pencil to drip a Dime-sized drop on a 3X5 Card. Apply fresh product to Manifold using a Small Artist Brush. Apply until the product "Pulls". New Card / New Drop.
    Pimp: Black Nail Polish from the SALE Rack at the Drug Store.
  21. kleraudio
    kleraudio Member
    Erie, CO
    Wait Rick, so no RTV sealant, liquid tape instead?
    Where are the pilot mixture screws? oh man now I'm worried :) I'll have my manual when I do this, hopefully they tell me what each part is...
    Emery board festival? You lost me there :)
  22. RickCoMatic
    Depends on the size of the Cracks.
    Some guys like RTV.
    Others dribble Plasti-Dip in them
    5-Minute Epoxy
    Bicycle Inner Tube.
    An "Emory Board Festival" is using a bunch if them to Sand and Beautify the Repair before applying a cosmetic finishing touch.
  23. kleraudio
    kleraudio Member
    Erie, CO
    About to pop off the first float bowl after dinner. . Wish me luck :)
    As far a wet setting. I'm gonna just use the graduated tube from Len. Ill have to put in an order tomorrow. Ill adjust using that and a long piece of fuel tubing. Hopefully I can get the order quick. No riding this weekend it looks like.
    That's cool though. Do I need to break the rack to clean enrichment circuit?
  24. kleraudio
    kleraudio Member
    Erie, CO
    So I followed Rick's guide along with my Haynes, but I only did carb 1. Still took the whole enrichment rod out and cleaned all the enrichment valves.
    But here's the thing. The carbs are really clean already. No screws were tough to get out, all the jets were clear, everything was just fine. The one thing I did find was there was a rock under the screen of the float valve seat. Would that have caused gas to leak into the crankcase? This was only carb 1. 2, 3, and 4 are tomorrow. There were also several tiny little pebbles in the valve seat under the filter screen.....
    With that all said, I'm kind of upset I pulled the carbs as I don't have any tools to sync them with and they are literally spotless.
    I'm starting to think the fautly petcock is to blame for gas in airbox and crankcase, God only knows how long that thing was leaking. On position was basically prime but a little slower flow. I think in time, even if the floats are correct it would cause leakage.
    Anyways, I'm going to do the other 3 carbs since this thing is out anyways, but I don't plan on finding much. Carb 1 passed the clunk test with flying colors. I just don't know what the issue is. But my oil definitely smells like gas. What is this about a YICS tool to sync the carbs? Is this true?
    Here's a pic of carb 1 when I took the float bowl off, (jets removed)
  25. bigfitz52
    They're not "spotless" if you've been finding little rocks and pebbles in the beanie screens.
    You also need to take them apart a tad further; pull the emulsion tubes. Clean thoroughly inside and out. Pull the pilot mixture screws and replace their tiny o-rings and be sure those passages are CLEAN. Make sure the enrichment "wells" in the float bowls (where that long tube goes into) are clear. Inspect inside the float valves, look at the seats; polish if necessary. Inspect the tips of the float valve needles, replace if worn, damaged or hard as a rock. These two items are critical, you had a float valve issue.
    DO NOT USE SANDPAPER in carbs. Carb cleaner, rags, maybe some Scotchbrite. And ONLY if carb cleaner on a stout rag won't get it clean.
    SLOW DOWN. You're on the right track, don't rush it and end up joining the "I've cleaned my carbs five times" club.
    Don't fret the "lack of tools" for doing your final vac sync. There are "shade tree mechanic" solutions for both a manometer and to block YICS.
    And one last item: IT'S NOT THE PETCOCK'S FAULT. You could hook a hose DIRECTLY from the tank to the carbs and IF THE FLOAT VALVES ARE WORKING CORRECTLY THE CARBS WILL NOT FLOOD.
    A leaky petcock ony ENABLES the issue; the float valves not doing their job is the root cause. I've accidentally left mine on PRI for a week and nothing bad happened, because my float valves work correctly.
    wgul likes this.
  26. kleraudio
    kleraudio Member
    Erie, CO
    Thanks Fitz. I got the sandpaper to do the clunk test per Rick's advice, I wasn't going to sand anything else. But it passed the clunk test.......
    Pilot screws, do I have to count the amount of turns it takes to get them out? I did not do that on the first one, but did on the others....
    What does a 'worn' float needle tip look like? Mine looked pretty good. When you say emulsion tubes what do you mean? Is that the tube that is lifted when I turn on the choke? If so I took all 4 out and wiped down with carb cleaner, but they were already very clean to begin with.
    Can I spray carb cleaner down the hole where the pilot screws were removed? I didnt know if I should do that yesterday or not.... I can remove the pilot screws again tonight and spray down there though.
    I guess I'll just clean them up really good and order new pilot screw o rings. i only have that workspace until Sunday though so I don't know how I'll install the new parts. I've read that new float needles aren't exactly the same length as the stock ones in the bike, will that mess with anything in the seats, because those look just fine and I don't want to replace those. Hell, I think my float needles are fine too, but something is letting gas flow to my airbox/crankcase....
  27. kleraudio
    kleraudio Member
    Erie, CO
    Oh, the emulsion tube, that's the one under the main jet right with the holes in it? I pulled that too. Spotless. Could see through each and every hole on to the other side. I still sprayed them down, but yea, no cleaning required on those, I'm telling ya, this thing looks like it was recently cleaned by someone....
    Still doesnt explain gas in the crank case. Heres the thing though, if they cleaned the carbs, but left the airbox "gassy" could that be why I'm still smelling fuel in the crank case? Should I order a new air filter too?
  28. bigfitz52
    Gas in the crank case was because one or more float valves did not stop fuel flow as it should. Period. We've covered that.
    You spray carb cleaner through every hole and passage in the carbs; YES down the hole where the pilot screws come out of. You can count and make note of the original positions of the pilot screws, but just for "reference." You're going to set them all at 2 1/2 turns out to begin with.
    As for the emulsion tubes, the INSIDE BORE is often overlooked.
    Your incorrectly operating float valve could simply have been due to a previous mechanic's failure to properly set the float levels; or by one of those "pebbles" getting caught between a float valve and its seat.
    And if your air filter is oil or gas contaminated/saturated then by all means replace it.
  29. kleraudio
    kleraudio Member
    Erie, CO
    Fitz, the inside bore of the emulsion tube? emulsion tube is the tube under the main jet correct? I looked through the holes and clearly saw out the other side, would that mean the 'inside bore' is good to go? Again I only did carb 1 so I can go back in if need be. I also sprayed into the center and it came out the other side.... I just want to make sure emulsion tube means the same to both of us lol!
    2 1/2 turns out? Does that mean tighten all the way and loosen 2.5 turns?
    The pebbles weren't in between the needle and the seat (I don't think) the pebbles I saw were outside of the filter of the seat. If that makes sense, surely one or two tiny ones probably got through that filter, but from what I could see, the pebbles were outside of the seat screen..... You can actually see the pebble in that picture I took a few posts back.
    I haven't looked at the air filter yet, but there is a K&N sticker on the airbox... If I just order a stock air filter (KN too pricey right now) it'll fit no problem right? i'd like to order that today but should I look in the airbox first? I'd have to wait to get home for that.
    Thanks again man, I'm looking forward to fixing these issues! I've read Len's wet set guide probably 100 times so far, not sure how i'm gonna pull this off really, but I'll do my best!
    Oh, and lets say the floats are set incorrectly, shouldn't the needle still close on the seat regardless of where the float level is? unless it's too low I guess then that needle would always be in the down (open) position right?
  30. kleraudio
    kleraudio Member
    Erie, CO
    There is a ring around the needle tip. No scratching or anything like that, but just a ring where it rests in the seat. That is OK right?
    The needles Len sells are 1mm longer than OEM and I'd like to stay with the correct size so I don't pull my hair any more than I hvae to with this wet set that I still have no idea how to do but will attempt anyways!
  31. bigfitz52
    The ring "from where it rests in the seat" is a WEAR line. That is a WORN float valve. I'm pretty sure Len has both OE and aftermarket parts, maybe not. Even so, 1mm difference will be easily adjusted for.
    As for "wet-setting" float levels, I believe this: http://www.xj4ever.com/setting%20fuel%20levels.pdf has been posted more than once in answer to your queries. Simply read it carefully and follow it; it's not difficult. You don't need a fancy stand; just any way to hold the rack upright and level in all directions. I just "pad" my bench vise w/cardboard and use that.
    Because you can see through the little holes in the emulsion tubes DOES NOT mean that the inside bore itself is clean. Yes, I'm talking about the "tube under the main jet." Be sure the inside BORE is as clean as the outside. Take the tube out and LOOK through it; not just through the little holes. The emulsion tubes need to be clean inside and out.
    Yes, 2.5 turns out means 2.5 turns back from gently bottomed.
    I would highly recommend a new, stock paper air filter over a K&N. If you already have a K&N fitted, it may contribute to tuning woes. You definitely want to LOOK and see what you're dealing with.
    And no, it is entirely possible for a float to be mis-adjusted in such a way that it never shuts off.
  32. jmilliken
    Dillsburg, PA
    I suggested using standard tools to save money IF he was going to replace the screws anyway.
    forgot about these buggers... Chacal used to sell a special tool for these guys.. dont know if he still does. I took a flathead screwdriver to a bench grinder and made my own (i make a lot of custom tools)
    Wet setting isn't hard. It's just annoying and time consuming.just touching the float tang will move the fuel level about 30 feet (ok seriously maybe about 1mm) first time i did it i went back + forth between flooding and empty bowl like 5 times. it's just like most other things on here. it takes patience and time (and a few beers) but you'll get it right. then you will look back on it and say "that wasn't so bad". then you'll start looking for a new project bike
  33. kleraudio
    kleraudio Member
    Erie, CO
    Thanks Fitz, just ordered a stock paper air filter. Looks like I'll need new float needles, that wear isn't bad but it's still wear I guess.... Waiting on Len to email me back so I can order those up. Yes, I've read that PDF countless times. where can i get a long tube to remotely send gas from my tank? what size does it need to be? Doesn't say in that pdf.
    I can't think of a way to make those carbs level when doing the wetset, I'll think of something i guess!
  34. sektorgaz
    sektorgaz Member
    Western MA, United States
    You need a fuel line from any parts store. Get the same diameter as your current hose from tank to carbs (probably 3/8 inch).
  35. k-moe
    I would add that using your bike's fuel tank while setting floats is a PITA. I converted a coffee can to a remote fuel tank by using a nylon fitting (barbed on one end, threaded on the other) a neoprene fender washer (as a gasket), and an appropriately sized jam nut. It doesn't drip, I can cover it with it's own lid to reduce fire risk, and it sits nicely on the bracket I made for my pegboard. Total cost was under $10.00 (including the fuel line).
  36. kleraudio
    kleraudio Member
    Erie, CO
    Milliken, I'm sure it's not hard but I have basically no space and I can't feasibly think of a way to get these carbs to sit perfectly level!
    If I need to lower the fuel level, which way do I bend the 'arm'?
    Man, looks like I'm gonna need to wait on float needles to arrive in the mail... another week down on the bike and the cold weather is almost here!
  37. k-moe
    DYI Carb Stand
    To lower the fuel level you "nudge" or "tweak" the the float tab toward the needle.
    I know it's difficult when you want to ride but can't. Think of it in the long-term. You can't really enjoy the bike as it is now, but once all the work is done you'll be having fun for many seasons of riding (and only needing to keep up on regular maintenance). If you don't do the work you'll never get to truly enjoy the machine; you'll be cursing it for "breaking down" all the time.
  38. kleraudio
    kleraudio Member
    Erie, CO
    That carb stand is sweet! What does he mean by smooth/threaded?
    That's a good point man, but I bought a bike to ride this year, I've always wanted one (30 years old now) and finally got one. You know the feeling. I might just get a bottom end rebuild kit from len for 100 bucks using bill me later just so I can get riding again. If wet set is done correctly and I used the bottom end rebuild from Len (needle and new seat with filter) my gas in crankcase woes should be solved.
  39. jmilliken
    Dillsburg, PA
    i built an even cheaper carb stand out of plywood, some L brackets and screws laying around ... total out of pocket cost $0.00
    I went through 2 years of this. If you want to ride now, sell this bike and drop 8-10 grand on a new one. If you want something that trancends the experience of buying a bike... keep working on this one. the knowledge that you will gain through this resurrection experience is invaluable. Not to mention the satisfaction and looks that you get when you tell people that you (re)built that.... Fitz has posted this story before.... someone told him that they liked his new bike... then he had to explain to them that it was actually 30 years old.... and they didn't believe him.... My neighbor spends about 3 grand a year maintaining his fairly new harley (not mentioning the upgrades). I can do anything to my bike for the cost of parts (and beer)
  40. kleraudio
    kleraudio Member
    Erie, CO
    Right on Milliken, that's what I needed to hear! I'm gonna take my time and do this right. Plus all I need for the carbs are o rings for the pilot screws, float needles, and seats. I found a rebuild kit on amazon for 16 bucks. I'll get 4 of them. The carbs are very clean, just leaking gas into the crankcase, I think this will solve it, what do you think?
    http://www.amazon.com/Carburetor-Repair ... carburetor
    I'll have to ride on bench synced carbs for a month or so till I can afford the proper tools, but I think if I'm meticulous enough I can get really close. Then i'll do a colortune... First things first, get the gas out of the crankcase! Would that set do me right you think?
  41. kleraudio
    kleraudio Member
    Erie, CO
    Should I get those on amazon, or Len's got pretty much the same thing, minus the gasket, but the seats come with screens for 100 bucks. Kind of hate to spend 40 bucks more for screens, are they really necessary?
  42. RickCoMatic
    While you have the Jets and Main Nozzles (Emulsion Tubes) out; FLUSH the AIR and FUEL "Passages".
    Use a Bubble Syringe.
    With the Syringe filled with a few ounces of Carb Cleaner:
    Flush the Main AIR Passage thru the Main AIR Jet down to the orifice at the inside diameter of the Bore housing the Main Nozzle.
    Flush the Siphon Tubes thru the Enrichment Plunger hole.
    Flush the Pilot AIR Jet Passage thru the Pilot FUEL Jet port.
    Flush the Pilot AIR Jet thru the Pilot MIXTURE orifice while plugging the Pilot FUEL Jet housing.
  43. kleraudio
    kleraudio Member
    Erie, CO
    Thanks Rick. I did all of this tonight. It was already very very clean and no jets were jammed up whatsoever.
    The thing that troubles me is I sprayed the enrichment circuit section on the float bowl and got the big long stream of carb cleaner (not in my face, pointed that thing AWAY from me) on all four float bowls. I pulled all the pilot screws and all the plungers. Any idea why my bike won't start unless I push the start button AND throttle a few times at the same time? With the carbs this clean, why doesn't the bike just fire right up when I push start?
    Thanks everyone for the help. Now I need to figure out how to remove these very stripped drain screws.....
  44. Polock
    Theory, floats leak a little, that's richness, when u open the throttle at cranking rpm you add air and it starts. If u start with choke u add extra gas to what already leaked in and that makes it too rich.
    Fixing the floats may change how it starts
  45. Polock
    There's a writeup on kzrider.com about jis drivers in the tools forum, check it out
    I'm on a phone and links are just too hard
  46. kleraudio
    kleraudio Member
    Erie, CO
    Polock,
    When you say fixing the floats, you mean the float height? Or the needle and seat?
    Plugs are black. So it's definitely rich.
  47. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    see the write-up in your other thread about removing stuck float bowl drain screws....propane torch & olive method was great....hopefully your screws aren't all buggered up....& you can get some meat of the Phillips on it....be patient...they will come off.....last resort...use screw extractor bit....
  48. Polock
    Come on man, I'm old, typing on a virtual keyboard on a smart fone.
    Gimme a break. Floats to me is the black plastic things and everything associated with them.
    If all the parts don't work, nothing works and the floats leak
  49. kleraudio
    kleraudio Member
    Erie, CO
    Polock, you're a funny man. Ordering new seats and needles from Len. :)
  50. Polock
    did you take off the c clips off of the ends of the throttle shaft and have a look at the 2 outside seals?
