CLR on rusted shocks
Discussion in 'XJ Modifications' started by irishladjbl, Apr 17, 2007.
  1. irishladjbl
    irishladjbl Member
    Monterey, Ca.
    I guess this is more a cleaning then a modification but I thought the info could be useful. These shocks are off my 82 xj650rj. Before I got the bike it had been sitting outside for about 6 years. Even though they are completely functional I almost got rid of them so I could get some nice new ones. Just to see how they would clean up I used some CLR and a wire brush and... well I thinks it saved me about 300 bucks.
    The shock on the bottom cleaned up even better the the one on the top.
    The moral of the story? Try a little elbow greas before you throw that rusted part out.
  2. Robert
    Well done and how! I gotta get a little more creative when I poke at them, my brush won't fit in the coils!
  3. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Ok, I'm impressed.
  4. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Damn, I was going to buy a new set of shocks cause mine are getting pretty rusty, but if you can clean that mess up with CLR, then I'll save my money and spend some elbow grease!
  5. Alive
    Alive Active Member
    Queensland, Australia
    Nice cleanup there :)
    I've been buying a product over here called rust converter (cheap no name brand). I find it great stuff... Just hit what ever it is with a wire brush to remove loose rust then brush this stuff on, wait 10 - 30 minutes, wipe off with a damp cloth, wipe again with a meths soaked cloth and god damn it really works a treat, especially on chrome. It's nasty stuff and you have to be careful not to leave it on too long but the results are amazing and it takes quite a while before the rust comes back.
  6. chacal
    What is CLR and where does one buy it? In the USA, that is........!
  7. gremlin484
    gremlin484 Member
    Omaha, Nebraska
    Can be found just about any place that sells cleaning supplies... This particular pic is stolen from walgreens website, but I've seen it at walmart, grocery stores, hardware stores, etc.
    It's pretty common.
    YEAH! That was my 100th post!
  8. chacal
    Thanks!
  9. TaZMaNiaK
    TaZMaNiaK Member
    NJ
    <sigh>
    If only it could take the nasty crap off the aluminum on our bikes.. But great job on those shocks!
  10. gbuddyjoe
    gbuddyjoe Member
    New Hampshire
    Tried this on my shocks and exhaust cannister this weekend and mother of God does this stuff just rip the rust off of chrome!!!
  11. killer27574
    killer27574 New Member
    That is a really good idea i was going to through mine away and get new ones. But that made them shine like new
  12. mainexj550
    mainexj550 Member
    maine
    is it safe on the seals?
  13. Chitty
    Chitty Member
    Peru, Illinois
    Here are some things that the manufacturer says: http://jelmar.com/CLRbasic.htm
    I would think that seals are fine since you need to wear rubber gloves? Just make sure to rinse often!
  14. nammy
    nammy Member
    Upstate New York
    I've used it for the inside of the headlight bucket. Works great but you must treat it with someting to prevent rust from coming back. It can come back in a few hours after use.
  15. desmotom
    desmotom Active Member
    Canada MB
    I had the same problem with my shocks, they were rusty but still worked great. I removed the coil spring and buffed them up with some scotch bright and chrome cleaner, then I paint the coil springs gloss black. They turned out great. A little tricky getting the springs off though but was worth it.
