1982 XJ750 Bobber Project Bike
Discussion in 'XJ Modifications' started by 82NewToMe, Aug 5, 2012.
  1. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    Good looking bike man, we'll def need to meet up!
  2. 82NewToMe
    82NewToMe Member
    Stainless brake lines on the way, as is my fuel sight gauge and new black rubber grips for my 1 inch bars, progress...
  3. bobcat5540
    bobcat5540 Member
    Mount Sidney,Virginia
    What risers did you use to allow for 1" bars.
  4. 82NewToMe
    82NewToMe Member
    I used risers for HD, only mod I had to make was to slightly open up the bolt hole in the top of the tree to 1/2".
  5. bobcat5540
    bobcat5540 Member
    Nice,
    I am thinking that the 7/8" bars seem kinda flimsy. I used the top and bottom from an 83 and got rid of the Two piece bars. Now you have me thinking about getting something beefier.
  6. KDub
    KDub Member
    Burnley, NW UK
    I've added the brace in red. It doesn't necessarily have to be a hoop, just join the two ends of the frame together.
  7. 82NewToMe
    82NewToMe Member
    That makes sense, shouldn't be much work either, thanks.
  8. 82NewToMe
    82NewToMe Member
    Todays work, mocked up the fuel sight gauge, drilled my holes, removed debris from said drilling, sanded the paint around the area and sat back and stared at for a half hour or so....
  9. 82NewToMe
    82NewToMe Member
    And the postal service is killin me! I also ordered my new stainless brake hoses that should have been here yesterday, but nope, got missent out of a sorting facility, now when I track it it's in another town "out for delivery", grrrr, I want to install them and fill with fluid and be done with the brakes. So, what have I done with the brakes? New shoes in the rear, total rebuild of the calipers, new pads, new MC, and one day I might even have new lines, all upgraded to DOT5 being as the MC requires it.
  10. prince_albert3
    prince_albert3 Member
    Rochester, PA
    What is the length of the hose your using for fuel gauge? Where did you get the setup/cost? I'm really wanting to do this too. I found a pretty decent package on ebay for $29. They offer colored lines too...
  11. 82NewToMe
    82NewToMe Member
    Pandemonium Choppers, 20 bucks. I think the line is 10". They only offer clear but that worked because that was what I wanted. Monster Craftsman has a slightly more expensive setup,9.25" hose but lower profile fittings.
  12. prince_albert3
    Rochester, PA
    Thanks.
    The more I think of it, I feel like I could piece it together cheaper. I'll have to see what I can find. I like the sound of "low profile" fittings as well !
  13. 82NewToMe
    82NewToMe Member
    Most of the folks I know that pieced them together spent about 25 bucks, but no low profile,
  14. randomchad
    randomchad New Member
    Massanutten VA
    Harrisonburg! I live in massanutten and im in the same boat as you. First and current ride is a '82 XJ550 with about 20,000 on it. Im working on the bike trying to get it how i want it. We should get together sometime and ride!
  15. 82NewToMe
    82NewToMe Member
    Mine isn't on the road yet, but after my brake lines show up, I replace my fork seals, exhaust and rebuild the carbs it will be, sounds like fun for sure.
  16. 82NewToMe
    82NewToMe Member
    USPS!! Dang, brake lines are traveling around the state of Virginia, but not in the way I think they should (you know, on the fron of my bike!)
    On another note, my gas tank is at the welders having the bungs TIG welded in for the fuel sight gauge, that makes me smile...
  17. shangovi
    shangovi Member
    Burtonsville MD
  18. 82NewToMe
    82NewToMe Member
    It's going to look a lot like that, a bit longer tubing on mine with a curve to it.
  19. 82NewToMe
    82NewToMe Member
    Fuel Sight Gauge installed
      File size:
      82.1 KB
      1,608
      File size:
      68.2 KB
      1,606
  20. 82NewToMe
    82NewToMe Member
    I got the tank back from the welder, installed the fitting and tubing, secured and remounted the tank. Also got the new fluid in my front brakes. I rebuilt the calipers, replaced the hoses with SS lines, replaced the MC, replaced the shoes in the rear, tons of stopping power now.
  21. 82NewToMe
    82NewToMe Member
    Fork seals came in today, going to borrow my neighbors bike lift since my exhaust isn't on yet and I don't have a center stand anymore, plus borrow some of his brain... Biker neighbors are good to have around.
  22. 82NewToMe
    82NewToMe Member
    Pretty much done. Just put 15 miles on it. Need to take it to a pro and let them tune it for me, maybe next week.
  23. Newb21
    Newb21 Member
    Cardiff, South Wales
    That fuel guage is awesome!
  24. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    Agreed. I'm inspired and trying to think of other styles I can play with.
  25. thejewishguy
    thejewishguy Member
    Miami
    I used HD Sporster profressive shocks also but instead of grinding down the mounts on the frame i reamed the shocks eyelets with a 9/16" drill bit in case some day i decide to go back to stock shocks... It took a long time to do this reaming plus 2 drill bits... I didn't think to do what you did even thought that is simpler than what i did... I just thought about the possibility of sacrificing the integrity of the frame structure.
  26. biggyfaction
    biggyfaction Member
    cedar rapids iowa
    I have HD air shocks i bought off a buddy. drilled out the bushings on the shocks a little bit. alot better than messing with the stock mounts.
  27. thejewishguy
    thejewishguy Member
    Miami
    Where is the Like button on this forum?
    Can you post pics of your HD shocks on your bike?
  28. 82NewToMe
    82NewToMe Member
    And finished! Finally! All tuned in and ready to go, put about 50 miles on it today.
