Another flasher relay issue?
Discussion in 'XJ Modifications' started by Magiccowinuse, Aug 11, 2013.
  1. Magiccowinuse
    Magiccowinuse Member
    West Chicago, IL
    Ok so for about a year and a half my LED flashers worked perfect with an electronic 3 pin relay. About a month ago my flashers quit working. I checked connections and everything was OK.
    I am down to the conclusion that it is the relay. When I touch the brown and brown/white wires the signals light up. I can only assume that means everything else is OK, but I may be very wrong. This is what I found when I got to the relay:
    image by MagicCowInUse, on Flickr
    The heat had caused the electrical tape to squeeze the plastic cover. Assuming that caused an internal issue, I have purchased a different flasher relay from an auto parts store. They didn't have the same one in stock. The signals still will not flash. What are the colors for the positive (+) negative (-) and lamp (L)?
    I am trying to work with the relay on the left:
    image (3) by MagicCowInUse, on Flickr
    What is the correct wiring?
    Is there a possibility that this relay just isn't compatible?
    What else could be wrong?
  2. k-moe
  3. broberg
    broberg Member
    Sweden, Östergötland
    Get a 2-pin flasher. The led flasher for a car Don't work on our bikes. The design of the relay is different.
  4. IMWirtz79
    IMWirtz79 New Member
    West Bend Wisconsin
    you may have to eliminate the the use of the auto-cancel like had to. I bought an electronic flasher relay and had to run a new ground wire.
  5. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Ebay
    Worked great (no auto cancel) . 3rd wire to ground
  6. RickCoMatic
    "Somewhere" ... (I looked, ... but will be damned if I could find it) ... there is a Thread with a Members INGENIOUS solution to retaining Auto-cancel using an Electronic Flasher.
    Without a Dummy Load.
    I cant find it.
  7. billibong145
    billibong145 New Member
    On my 82' 550, I found that a flasher relay from a 79' Ford F150 matched the voltage and ohm requirements. I had to do a little wire modification as the pin-out location was different. Works great and I haven't had problems for about 3 years now. And my problems started where the turn signals were busted. I swapped out with set of 4 LED that I got on Ebay. Still had no working flashers. That is when I found out that my relay was bad. The Ford relay was less than $5.00 at my local parts store.
