Big Bore Kit
Discussion in 'XJ Technical Chat' started by amfmtxca, Aug 4, 2012.
  1. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    has anybody tried this big bore kit from ebay
    http://www.ebay.com/itm/130596518069?ss ... 1438.l2649
    Seller is cruzinimage_co
    I have a cracked cylinder on my XJ 750 Maxium and I have purchased a used replacement from ebay. I am curiouse about this kit if I need to bore the cylinder this could be an easy option, but I am cautious about buying from a seller from another country any help would be appericated
    Thanks in advance
  2. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Have you considered just replacing the sleeve where the cylinder is cracked? That may be a very much less expensive way to go. The sleeves are easy to press out. Any machine shop should be able to press in a replacement sleeve. I have no idea as to where to get one though. As for getting the big bore kit, you will have to get the cylinders bored.
  3. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    That's not a bad price for what your getting. If you go bigger you don't want to try and hone to get there. A master mill mech could maybe hone a round bore, I wouldn't try it as its way hard and would take forever, but if you do get it re-bored by a machine shop your compression should be stellar. Shop around if you go this route as some will straight up try to rip you off.
  4. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Thats what I got. I haven't started my engine yet from getting it bored. Cost me a bill to get it bored.
  5. amfmtxca
    amfmtxca Member
    streetbrawler750 I take it you had no problems getting your parts from Japan when you fire it up let us know how it turns out. I am looking at it for a winter project, along with a lot of other things that need attention. There are a few machine shops here that do MC work, I would not try to bore this myself. I am cautious of buying from ebay been burned once all ready.
  6. aaron_acrusto
    aaron_acrusto Member
    Pittsburgh, pa
    I've bought some brake parts for my girlfriends Honda from that seller. They showed up pretty quick too. I'd say go for it.
  7. pmjydnl
    pmjydnl Member
    Sydney Australia
    I am a bit late on this....but I have bought a fw items....including full gasket kit and had no problem. Arrived pretty promptly.
    My only problem with thi s"Big Bore" thing i sthat you are taking all the meat out of the cylinder walls. You go from the standard 65mm bore to 68mm and that is almost equal to the 4th size rebore. Anything goes wrong...you will need all new cylinder jugs....
  8. streetbrawler750
    Minnesota
    Yeah I had no problems, there was plenty of meat. If something goes wrong a guy might need more than jugs, might need the whole motor. Oh well, the risks we take....
  9. amfmtxca
    amfmtxca Member
    Thanks for all of your responses I am still kicking the idea around
  10. rigger
    rigger New Member
    australia
  11. rigger
    rigger New Member
    australia
    Hello mate'
    I was doing up my xj 750 and found one of my pistons had a chunk missing out of it couldn't find a standard piston anywhere for it plus set of standard rings until i found cruzinimage on the net and bought a set of rings for $40.00 here in Australia they where going to be $80.00 per cylinder but they only had three sets left here in oz so i have put my bike back together again after 4 years and will start it up next week so give that bore kit ago mate couldf work out just fine i was going to buy it myself cheers Tony
  12. k-moe
    Got punctuation?
  13. ingie1062005
    ingie1062005 New Member
    Armstrong B.C. Canada
    Just got the big bore kit myself. Have you bored your cylinders yet, and what clearances did you reference to the pistons? The machine shop I called said they needed those numbers so I emailed the seller. They said they didn't have that information.
  14. bigfitz52
    The piston-to-cylinder clearance specs are listed in the service manual.
  15. ingie1062005
    Yes I finally found the specs.! Took it to the machine shop, because the bore is so small they're charging me more as they have to use their small machine $340.00 + 12 % tax.
