Getting ready for the bobber...
Discussion in 'XJ Modifications' started by XJ1100, May 6, 2013.
  1. XJ1100
    XJ1100 Member
    Duluth, MN
    Hey all,
    I'm getting ready to tear apart my 82 XJ1100 and make a bobber. Basically, I'm going to lower the rear a bit but leave it a soft tail, replace the seat with a solo seat and pad for my lady, cut and wrap the pipes, straight bars, smaller single tach/speedo, and paint the whole thing black.
    I need new tires and I'd like to go as big as will possibly fit. I need your advice here. Best brand/model for all around use. Where to buy?
    Also, need suggestions for where to look for bobber parts. Seats, bars, speedo, tach, etc. I'd prefer black parts and I'd like to stay away from chrome.
    Any other major points you'd like to add, advice, thoughts, etc. I would greatly appreciate anything anyone has to offer before I tear her apart.
    I've been saving all winter and plan to start this weekend. You guys are ALWAYS a wealth of good information and I appreciate it!
    Thanks!
    Dave
  2. JoeyGKedd
    JoeyGKedd Member
    South Shore, Mass.
    Hey man,
    I'm doing a similar project that I dove headfirst into a couple months ago so here are a few basic pointers, as my mechanical knowledge is limited.
    1. Take pictures and label everything. Putting the bike back together is definitely a lot harder than tearing it down. Place everything in ziplock bags and write what it is with a sharpie. (bolts, nuts, anything!) When I undid any wiring I put painters tape on each end of the connection and wrote a number on it so I would know what connected to what.
    2. Try and go piece by piece rather than tear the whole thing down at once. Makes the project seem a lot less overwhelming. Although I know a lot of people on here dive right in and still have success.
    3. Overall I'd say just have fun with it and don't get too stressed. Wrenching on the bike is half the fun of owning it.
    Also, a lot of custom parts can be ordered from mikesxs.net and tcbros.com. Ebay can also be your friend. And Chacal on this sight is great for stock parts.
    Hope this helps! Good luck!
  3. XJ1100
    XJ1100 Member
    Duluth, MN
    Thanks buddy! I appreciate the comments.
    Anybody have any advice on tires? Need a new set and want a good, all-around tire. I only drive this 3-4 months (Minnesota) out of the year, so I'd prefer safety, quality, and comfort over long life. I'd even pay a bit more per tire for something good.
    Anyone else have ideas where to pick up bobber parts? Bars, gauges, etc.?
    Thanks and keep the comments coming.
  4. Ted
    Ted Member
    Sioux Falls, SD
    Hey I look forward to seeing your project man! I've had pretty good luck finding parts on http://www.lowbrowcustoms.com/ and http://www.tcbroschoppers.com/. They both seem to have good service & quality from what I've ordered so far. TC bros. makes the only bolt-on forward controls for the XJ's that I've seen or heard of & they're pretty reasonable. http://jetsrus.com/ is a good source for jets & some other bits and if all else fails I go straight to ebay.
  5. XJ1100
    XJ1100 Member
    Duluth, MN
    Thanks.
    Is there a big difference in part fitment from an XJ650/XS650 and an XJ1100? Most of the sites reference the 650's.
    Any thoughts on tires?
  6. Ted
    Ted Member
    Sioux Falls, SD
    Well... it all depends on the part. Some things are interchangable like.. handlebars & controls should all be 7/8" diameter but if your doing a custom bobber there will definitely be some custom fabrication required for the seat, gauges, etc.
    I got Pirelli Route tires from Bikebandit.com. Decent price & so far I'm happy with them but this is my first bike & first set of new skins so it's hard for me to give an opinion. If you do some searches on the forum here there are a couple of good threads out there where it's been almost beat to death. It all comes down to your riding style and the look you're going for. If I could do it again I would get some whitewalls (and probably will in a couple years when the Pirellis are toast).
    To lower the rear I got a set of used shocks from a Suzuki Savage 650 & they work fine but might be a little weak if you're going to ride 2-up.
  7. XJ1100
    XJ1100 Member
    Duluth, MN
    Thanks Ted,
    I've looked at Perrelli's, Dunlop's, Michelins, etc I just don't know much about tires, load ratings, street feel, etc. I guess I'll just do more research and shoot from the hip.
    I plan to change the bars and add a simple tach/speedo. I just don't know if there are specific equipment requirements when it comes to the tach and speedo or if anything will work?
    As far as the rear, I'm probably not going to go much lower than the stock frame. Just removing the large 2up seat will make a huge difference. I'm going to add some beef to the fender and put a "pad" there from my girlfriend on the occasion she wants to ride with me. We don't plan to do long distances on the bike anyway.
  8. tcoop
    tcoop Active Member
    South Weber, Utah
    To get rid to the XJ1100 gauges you will need to do some re-wiring do to the fact that the headlight is powered through the LCD display. (but you already knew that)
    With the shaft drive you are not going to be able to go much bigger on the tire. I have Elite-II on mine that have raised lettering and the letters have rubbed off from the shaft drive (the size might be 140/90 but I will have to check) the stock tachometer is ran off the alternator so after market tachometer would require some re-wiring.
    the square handle bars I believe can be removed including the mounting points and add risers to add different style of bars. It also is possible to swap out the top tree to a XS1100 Special tree to use 7/8 in bars, but I am not sure if the air presure balance piece (not sure what it is called) is affected.
  9. XJ1100
    XJ1100 Member
    Duluth, MN
    Good info tcoop! Thanks!
    As for the wiring, I did not know that. But, I have an aftermarket lamp on the front anyway so that shouldn't be an issue.
    I don't need to go bigger on the tire. Just thought it might give it a more aggressive look.
    Can't you buy an aftermarket tach that would run off the alternator?
    I believe I can remove the square bars and add 7/8" straight bars on it. But, I'll tackle that when I get there.
    Thank you all so much for the info. Any more tips and advice you can offer would be great!
  10. JoeyGKedd
    JoeyGKedd Member
    South Shore, Mass.
    I went with Dunlop 404's on my 750. Haven't had much use with them yet, but the PO had the same tires on the bike before and it rode nicely when I first got it.
  11. newbike91
    newbike91 Member
    South Haven, MI
    I got my drag bars ans solo seat from lowbrow customs also. Got a good deal on some 10.5 inch burly sportster shocks for the rear on ebay. Just ordered new tires from motorcyclesuperstore.com. 150 bucks total for front and rear shinko 777 whitewalls. Exhaust wrap from amazon.com and new muffler from oldbikebarn.com. I shop around for deals. When I get around to new gauges I'm thinking mikesxs.com, although I think dimecitycycles carries the same ones so I will compare prices. Hope this helps.
  12. XJ1100
    XJ1100 Member
    Duluth, MN
    The bobber project tear down should be starting soon. I just bought some new Dunlop D404's (front and rear), Bikemaster Daytona bars, new carb boots, new 54mm pod filters, and a solo seat with springs.
    I need to figure out how much exhaust wrap I need to wrap all four pipes. Anyone have any idea how many feet?
    I'm also looking for a black headlight bucket with an upgraded bulb for better lighting. If anyone has any ideas here, I'm all ears.
    The gauges are proving to be an issue too. Nothing seems to "fit" or "work" with my bike without re-inventing the wheel..... The only thing I've found that might work is here:
    http://www.dimecitycycles.com/vintage-c ... 53-bk.html
    It's a bit more than I wanted to spend, but I'm getting frustrated and just want to get this project moving. Nothing else seems to work on these XJ's.
  13. XJ1100
    XJ1100 Member
    Duluth, MN
    Quick questions for you XJ Bobber Guru's.....
    1. What did you use for exhaust? I want it small, simple, not too loud, but with a NICE low rumble. My XJ is an 1100 so it's a pretty big engine. I don't want it sounding like a Japanese weed whacker........
    2. I plan for it to be a "single seat" bike.....most of the time. However, I'd like to have the option to take my girlfriend for a ride now and then. But, I don't want to have two seats permanently mounted. Any thoughts here?
    3. I will be ditching a lot of the stock parts; speedo cluster, stock seat, stock bars, etc. Does anyone need anything? Let me know.
    If anyone has any advice, ideas, or warnings before I tear it apart, please feel free to chyme in anytime. I welcome ALL ideas and advice!
    Thanks! You guys are great!
  14. MattsXJ
    MattsXJ New Member
    Florida
    I built a "custom" housing for my speedo. I used an old bearing and gently cut out the old lip and glass. The glass has that cracked look from age but I like it so I kept it. I really need to post my 1100 build but Im waiting until its finished although knowing me it'll never be finished.
    Also if you need help with the wiring theres a min wiring diagram on here that helped me. If you need any help feel free to pm me.
    http://imgur.com/jtyCWo1
  15. Ted
    Ted Member
    Sioux Falls, SD
    1. I got these: http://www.oldbikebarn.com/MUFFLER-SHOR ... ry=3224599 they definitely fit the description & have a pretty nice tone. Maybe I can try to get a video up here for you later if you like. They do have removable baffles so you can adjust the sound a little by removing them or wrapping them with more/different material. I ended up actually leaving the baffles in because it sounds a little fatter but might try re-wrapping them at some point. I've read elsewhere that it tightens up the exhaust tone a little.
    2. This is a common conundrum and not an easy one to solve. A lot of it depends on your rear fender setup and how big your girlfriend is. :lol: This could be a good option: http://www.ebay.com/itm/SUCTION-SEAT-PI ... 2691wt_855. There's a few different styles out there too, of course. This is just the first one that popped up for me. I'd like to get one too but my rear fender has basically no support so I need to rethink the design to ride 2 up.
    3. Nope :)
    Otherwise my only suggestion would be this: you mentioned that you're keeping the softail frame (good choice, me too!) and you have a solo seat with springs. I always think bikes look really awkward with shocks and seat springs. Especially if you're not doing much modification to lower the seat area of the frame. It just rides way too high and looks goofy but just my opinion. Everyone has their own tastes, right? I have no seat springs & 10.5" shocks from a little Suzuki Savage 650 & the ride is just fine. To be honest though.. I'm still trying to talk myself out of hardtailing the frame & getting a different solo seat with some springs. 8)
  16. Ted
    Ted Member
    Sioux Falls, SD
    Oh yeah, exhaust wrap:
    http://www.ebay.com/itm/121114267099?ss ... 2500wt_855
    I bought 2 of these 50 foot rolls but I could have definitely gotten away with 1 and I wrapped all the way down almost to the end of my shorty mufflers. I did end up tapping into the 2nd roll because of some stupid rookie mistakes (first time :oops:). If I was to do it again (which I might) I would probably go with a narrower wrap, maybe 1" wide instead of 2", because it was impossible to wrap the angles on the exhuast collector without getting some ugly wrinkles & folds.
  17. XJ1100
    XJ1100 Member
    Duluth, MN
    Thanks Ted! Good info.
    If you're able to get a quick video of the bike running with those shorty pipes, that would be great! From your description, it sounds like what I'm looking for as far as exhaust.
    I've thought about a removable pillion pad, but never saw one with suction cups! Crazy! Not sure how that would work, but it's worth looking into as an option. The frame extends far enough back to the fender to support a rider, so that just might work. But, PLEASE keep the ideas coming for the "occasional" two seater....
    I goofed up. I am NOT keeping the soft tail AND adding a spring seat. I'm keeping the soft tail and adding a single "non-spring" solo seat. Sorry for the confusion. I think they look funny together too!
    Dumb question: How does the exhaust wrap stay in place? I know you use stainless zip ties, but how many??? Does it slide around or bunch up after a while? I'm considering just painting the exhaust black and calling it a day.
    Thanks again for all the good info. I love this forum and the wealth of knowledge from the members inside!
  18. JoeyGKedd
    JoeyGKedd Member
    South Shore, Mass.
    You only need to secure the exhaust wrap at either end of the pipes. You actually wet the wrap and wrap it as tight as you can get it, and it keeps itself in place.
  19. XJ1100
    XJ1100 Member
    Duluth, MN
    OK, now the choice. Should I wrap or just paint the pipes? I've heard that wrapping can speed up the corrosion process?
    Any other ideas for the occasional "two up" bike? I would say 80-90% of the time I'll be riding solo. But, it would be nice to be able to take her for a spin now and then. Ideas?
  20. Ted
    Ted Member
    Sioux Falls, SD
  21. XJ1100
    XJ1100 Member
    Duluth, MN
    Hey guys, I'm at the point of trying to figure out the seat issues. How to mount the solo seat and how/if I mount a pillion pad so I can take my girlfriend for a spin now and then.
    Ideas on a mostly solo XJ bobber with an occasional 2up rider?
    I need ideas! I'm open to all! Thanks!
  22. tcarr289
    tcarr289 New Member
    eastern nc
    I.m thinking of doing this to my 82 650 maxim also. What I'm working through in my head right now is fabing a sissy bar/ pillion seat combo on its own frame, which I will be able to attach to the frame of the bike, maybe under the seat. I will make it so it is quick to attach/detach, like maybe 4 bolts. I'm sure it can be done (probly has been done), but not sure how I am gonna do it yet. i'll try to make a thread when I get around to doing it, but it might be a while seeing I'm gonna be out of town till Early Oct. Looking forward to seeing your progress
  23. tcarr289
    tcarr289 New Member
    eastern nc
  24. XJ1100
    XJ1100 Member
    Duluth, MN
    Holy expensive seat Batman!
    Yeah, that's a bit more than I wanted to spend. I spent a whole $400 on the bike and I'm spending a little more to turn it into a bobber. I can't afford to spend that much for an occasional seat. It's going to be a solo bike for the most part, but I would like to take the girlfriend for a ride now and then.
    I do appreciate the idea though! Thanks!
    Any more ideas? Something simple, inexpensive, and removable?
  25. tcarr289
    tcarr289 New Member
    eastern nc
    Yeah, too expensive for me too. I only paid $500 for my bike. I'm planning on making my own and just use the pic as an idea for designing one.
    Your best bet will probly be the suction cup seat someone mentioned before. A friend of mine uses one and it works well. Hope you find a solution.
  26. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    it's "Harley" that's why it's ungodly expensive
  27. XJ1100
    XJ1100 Member
    Duluth, MN
    Thanks to you tcarr for the idea though!
    I'll probably just go with a suction cup design. Cheap, easily removed, and they look decent. She won't be on it much anyway.
    If anyone else has any ideas, I'd love to hear them! And thanks to everyone who has tried to help so far!
  28. XJ1100
    XJ1100 Member
    Duluth, MN
    I'm re-thinking the suction cup pillion pad idea. I just don't like the way they mount and I want to keep my girlfriend on the bike when we go for a ride.
    I'm going with a soft tail and have a single non-spring solo seat. There is plenty of room behind me for a passenger pad, but I can't seem to find one with rigid bottom, bolts, or bolt holes to be able to hard mount it to my bike without spending a small fortune.
    Does anyone have any ideas where to look for a removable, bolt on pillion pad that's not going to set me back too much?
    I'm looking forward to getting this thing done, but need to figure out the seat issues so I can tell how the rest of the lines are going to look.
    Thanks again for everyone's input so far!
  29. Orange-n-Black
    Memphis Area
    I would get a rear seat from a 85-86 Max or Virago. Uses 2 screws on the front thats hidden by the front seat, but you'll need to rig a small c-frame for the rear to hook into.
  30. XJ1100
    XJ1100 Member
    Duluth, MN
    Love the suggestion. Thanks!
    Will it fit on my frame? Any idea how wide they are? I know anything I do will be a custom job and require some modification. I just want something removable, comfortable for short rides, not too expensive, and something that doesn't look too goofy and out of place.
    Again, it's going to be a solo bike for the most part. But I would like to take my lady on a ride now and then. Hence the "removable" part.
    Thanks and keep the suggestions coming! Anyone have pictures of what they did for an occasional 2-up bobber?
  31. Orange-n-Black
    Memphis Area
    The 85-86 Max rear seat is 12" long and 10" wide.
    Have you had a look at J&PCycles.com? Look at the Virago and V-Star seats.
  32. XJ1100
    XJ1100 Member
    Duluth, MN
    I looked on JP for seats. I really didn't find much under $100. I can't believe there aren't cheaper options out there.
  33. MarkV
    MarkV Member
    Vermont
    I made my own, check it out in my gallery.
  34. XJ1100
    XJ1100 Member
    Duluth, MN
    Sorry for the confusion. I have my solo seat. I'm looking for a removable passenger seat or possibly a pillion pad. It's going to be mainly a solo bike, but I'd like the option to take people for a ride now and then.
    I'm having a hard time believing nobody else has done this or has any good ideas. It has to fit within the rear frame behind my solo seat, I'd like it to be removable, and I'd also like it to be somewhat comfortable. At least for a short ride. I'm also trying to do this on a tight budget. There are many options out there, but most are too expensive. It's also hard to tell what will fit and what will look good on the bike from pictures. I was hoping somebody has done this and had some ideas or pictures.
  35. MarkV
    MarkV Member
    Vermont
    XJ1100, do do have a close up picture of your seating so we can see what we are dealing with. I will check it out later, heading out, Killington Classic baby.
  36. XJ1100
    XJ1100 Member
    Duluth, MN
    Sure, this is a mock up of how the solo seat might look on the bike. I'm trying to picture a passenger seat or pillion pad that could mount behind it somehow. I don't want it to sit up too high. I like the look of the lower rear end.
    I don't know how to post it. It keeps saying the file is too big. I'm not sure how to shrink it to fit the attachment requirements.
  37. XJ1100
    XJ1100 Member
    Duluth, MN
    I hope this works...
      File size:
      51 KB
      1,347
  38. RookieRider
    RookieRider Member
    Gatineau, QC
    make your own... and use 2 of these broom wall mounts.
    one on each side of your pad and snap on the frame rails...
    Just a thought haven't actually done it myself.
  39. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    I like where that idea is headed.
  40. Orange-n-Black
    Memphis Area
    That's a good idea RookieRider.
  41. XJ1100
    XJ1100 Member
    Duluth, MN
    Yeah, no kidding! Never even thought about something like that. Good idea, thanks!
    I don't have the ability/skill to make my own seat, but I might be able to modify another seat or pillion pad to make it work.
    My biggest issue is figuring out which seat will fit best without buying a bunch and trying them out.
  42. RookieRider
    RookieRider Member
    Gatineau, QC
    Me and the wife bought a used rower a few years ago for 15$....
    Something like this... the seat is about 7X9 inches... just big enough for your butt cheeks....
    maybe if you find one a a good will store or something....
  43. XJ1100
    XJ1100 Member
    Duluth, MN
    That's actually a really good idea! Never would have thought about that.
  44. XJ1100
    XJ1100 Member
    Duluth, MN
    I thought I'd share a couple pics. One showing the project's starting point and a few showing the progress so far.
    I threw one in showing the removable Honda Rebel passenger seat. I don't care for the look, but it will work for the occasional 2-up ride when I'm giving my lady a ride.
    Again, it's easily removable and won't be on there all the time. I am really liking all the flat black....
    cmmoriarty likes this.
  45. XJ1100
    XJ1100 Member
    Duluth, MN
